Guest Posted February 11, 2018 Report Share Posted February 11, 2018 Double checking, if units are deployed outside of 9" from enemy models, what is the minimum distance required for a successful charge (without them moving in the movement phase)? I've been playing, and having it played against me, that deploying just outside of 9" means you need a 9" charge to successfully. It was suggested to me recently that being outside of 9" means that 9.00001" is the distance apart, so this means a 10" charge to reach base contact (which is required for a successful charge). Have I been doing this wrong? Quote Link to comment Share on other sites More sharing options...
WestRider Posted February 11, 2018 Report Share Posted February 11, 2018 It's a 9" Charge. You would need a 10 to make BtB, but in 8th, you only need to end the Charge move within 1" for it to be successful. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2018 Report Share Posted February 11, 2018 Ah, that's what I am missing. Thanks. Quote Link to comment Share on other sites More sharing options...
Psilence Posted February 11, 2018 Report Share Posted February 11, 2018 Wouldn't that make it an 8" charge? 9" from enemy targets. Within 1" to complete a successful charge. = 8"? Or am I wrong'ish? Math is hhhhaaaaaaaarrrrrrddddddd Quote Link to comment Share on other sites More sharing options...
PumpkinHead Posted February 11, 2018 Report Share Posted February 11, 2018 You have to deploy outside of 9". Meaning 9.00001 inches. If you roll an 8 for a charge you will be 1.00001 inches away from the unit charged and will fail the charge. Hence needing the 9 to make the charge. 1 1 Quote Link to comment Share on other sites More sharing options...
Psilence Posted February 12, 2018 Report Share Posted February 12, 2018 I had assumed that 9" meant 9", not 9.000001". I didn't notice where GW pointed out the decimal measurements. Not trolling, just wondering where others interpretations come from. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted February 12, 2018 Report Share Posted February 12, 2018 Within 9 means 9 and less per GW, so outside of 9 can't be within 9. After all 9=9, but the rule says must be deployed>9 Quote Link to comment Share on other sites More sharing options...
Edosaurus Rex Posted February 12, 2018 Report Share Posted February 12, 2018 I seem to recall GW stating that you need to roll a 9 on the charge in order to make it into combat after deep striking. I'm not sure if this was stated in an official FAQ or not, it may have been from a Facebook Q&A or something. Quote Link to comment Share on other sites More sharing options...
WestRider Posted February 12, 2018 Report Share Posted February 12, 2018 Yeah, it was in one of the FAQs. Main Rulebook or Designer's Notes, I think. The key point is that you have to Deploy more than 9" away, so on an 8" Charge roll, you will still be more than 1" away, which is a failed Charge. Quote Link to comment Share on other sites More sharing options...
Kelharis Posted February 12, 2018 Report Share Posted February 12, 2018 It has to be >9, otherwise you could deep strike and flamer in the same turn. Quote Link to comment Share on other sites More sharing options...
Psilence Posted February 12, 2018 Report Share Posted February 12, 2018 Gotcha. :) The flamer bit and the outside bit make sense. Quote Link to comment Share on other sites More sharing options...
Munkie Posted February 12, 2018 Report Share Posted February 12, 2018 I don't want to alarm anyone, but that <9-year-old is smoking! 2 1 Quote Link to comment Share on other sites More sharing options...
Steel Angel Posted February 12, 2018 Report Share Posted February 12, 2018 Bubble pipe Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted February 12, 2018 Report Share Posted February 12, 2018 1 hour ago, Munkie said: I don't want to alarm anyone, but that <9-year-old is smoking! Judging be his cheeks and pursed lips, I surmise the >9-months-old is blowing the pipe! Outrageously wasteful! Those parents, assuming single mother, should be ashamed! Quote Link to comment Share on other sites More sharing options...
