pretre Posted November 8, 2018 Author Report Share Posted November 8, 2018 23 minutes ago, Skkipper said: sisters in 2019 is like orktober. you will be able to pre-order the codex on 12/28/19. 1 Quote Link to comment Share on other sites More sharing options...
Lord Hanaur Posted November 8, 2018 Report Share Posted November 8, 2018 5 hours ago, Skkipper said: sisters in 2019 is like orktober. you will be able to pre-order the codex on 12/28/19. Yup. Aztec calendar could differ though. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 12, 2018 Report Share Posted November 12, 2018 At least they picked a fictitious month, instead of misleading us with a real month...like October. Quote Link to comment Share on other sites More sharing options...
Lord Hanaur Posted November 13, 2018 Report Share Posted November 13, 2018 On 11/12/2018 at 12:22 AM, paxmiles said: At least they picked a fictitious month, instead of misleading us with a real month...like October. You make a strong point. Quote Link to comment Share on other sites More sharing options...
WestRider Posted November 24, 2018 Report Share Posted November 24, 2018 The Adepta Sororitas are back – and better than ever Of course, Codex: Adepta Sororitas is one of the most exciting things about Chapter Approved this year, and we’ve had a chance to get an even better look at the rules. We’ll be previewing these in depth soon, but in the meantime, here’s another awesome Stratagem to tide you over: Quote Link to comment Share on other sites More sharing options...
Frowbakk Posted November 24, 2018 Report Share Posted November 24, 2018 It seems Combi-Flamers will be very common in units, especially the 4-Melta Dominions. Since it's just RANGE that matters for this Stratagem, and not actually having to have the Holy Trinity hat-trick hitting AND wounding AND opponents failing saves, it has some greater utility. Stick a Multi-Melta at the back of a blob squad and a Flamer at the front and Ye Olde Humble Bolter... ee is wounding Marines on 3+, and Knights on a 5+ at double-tap range. If there's a Relic that is like a 7th Edition Torrent Flamer or a Special Character with that ability, or an 18" range Flamer Lance or some-such it'll be an auto-include. Overall, even a +1 to Wound is OK, but the drawbacks of having to be in close range once again clash with the fragility of Sister to return fire. Not sure if it will be worth it. building an army around this Stratagem during list construction. Silly Thought: Since it just says this works on an "Adepta Sororitas unit", that would include vehicles. If (and it's a BIIIIG if) a vehicle could upgrade a Storm Bolter to a Combi-Melta then the Immolator could make use of it with all the same range. Wounding Marines on 2+ and Knights on a 4+ at 12". Holy Promethium, Batman! 1 Quote Link to comment Share on other sites More sharing options...
Dusldorf Posted November 24, 2018 Report Share Posted November 24, 2018 1 minute ago, Frowbakk said: It seems Combi-Flamers will be very common in units, especially the 4-Melta Dominions. Since it's just RANGE that matters for this Stratagem, and not actually having to have the Holy Trinity hat-trick hitting AND wounding AND opponents failing saves, it has some greater utility. Stick a Multi-Melta at the back of a blob squad and a Flamer at the front and Ye Olde Humble Bolter... ee is wounding Marines on 3+, and Knights on a 5+ at double-tap range. If there's a Relic that is like a 7th Edition Torrent Flamer or a Special Character with that ability, or an 18" range Flamer Lance or some-such it'll be an auto-include. Overall, even a +1 to Wound is OK, but the drawbacks of having to be in close range once again clash with the fragility of Sister to return fire. Not sure if it will be worth it. building an army around this Stratagem during list construction. Silly Thought: Since it just says this works on an "Adepta Sororitas unit", that would include vehicles. If (and it's a BIIIIG if) a vehicle could upgrade a Storm Bolter to a Combi-Melta then the Immolator could make use of it with all the same range. Wounding Marines on 2+ and Knights on a 4+ at 12". Holy Promethium, Batman! agreed about vehicles, but i don't think there will be any way to get all three weapon types on one. Quote Link to comment Share on other sites More sharing options...
Ish Posted November 24, 2018 Report Share Posted November 24, 2018 The Repressor (if GW continues to support the OOP model) has a Storm Bolter and a pintle-mounted Flamer... Put a squad of Meltagun Dominions in the rear and go proselytizing! Quote Link to comment Share on other sites More sharing options...
Dusldorf Posted November 24, 2018 Report Share Posted November 24, 2018 2 minutes ago, Ish said: The Repressor (if GW continues to support the OOP model) has a Storm Bolter and a pintle-mounted Flamer... Put a squad of Meltagun Dominions in the rear and go proselytizing! won't work since the repressor's firing port rules make clear that the unit inside is the one firing. to activate holy trinity the vehicle would have to count as firing the meltas. also just noticed that a vehicle will never be able to use the strat anyway since it says "one model...one *other* model...and one *other* model..." Quote Link to comment Share on other sites More sharing options...
Ish Posted November 24, 2018 Report Share Posted November 24, 2018 Ah, nice catch... Still, for a mere 1 CP, this is going to be a very useful Stratagem. I mean, every Sister and her Sister is carrying a boltgun, you were probably already going to put some combination of meltagun/multimelta/flamer/heavy flamer/combi-whatever into the squad as well... So to take full advantage of this, all you need to do is mix the types to ensure that between the squad’s Heavy, Special, and Superior you’ve got one of each. Quote Link to comment Share on other sites More sharing options...
pretre Posted November 24, 2018 Author Report Share Posted November 24, 2018 I disagree with wanting to mix though. Your hard hitting squads don't really want to mix. I think the best way to take advantage on Doms is to take a Combi-Flamer and an extra body. You definitely don't want to take it on Seraphim. BSS, on the other hand, I might start taking flamers on again. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 24, 2018 Report Share Posted November 24, 2018 I'm thinking it will become somewhat mandatory in coping with T8 should you want to be able to wound on 3s, rather than 4+. Main use, I'm thinking, is for melta squads. And rather than 4 melta, 3 melta+1 flamer and a sarge (Sister Superior) with bolt pistol. I'm thinking statistics are probably slightly better 3 meltas wounding on 3s rather than 4 meltas wounding on 4s, plus slight point reduction. If they allow dual pistols, could also go hand flamer+bolt pistol sarge, and then 4 meltas. That is, if fielding pure sisters. Sisters with allies don't really need this one. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 24, 2018 Report Share Posted November 24, 2018 Yeah, slightly better. 4 meltas is 2.667 hits, 0.889 wounds vs T8. 3 meltas with +1 to wound is 2 hits, 1 wound vs T8. Using a mathhammer program, not my own math skillz. here: https://www.mathhammer8thed.com/ Quote Link to comment Share on other sites More sharing options...
Ish Posted November 24, 2018 Report Share Posted November 24, 2018 I’m thinking that dedicated squads, like four meltagun Dominions (tank hunters) or four heavy bolter Retributors (anti horde), will be better served sticking to their dedicated task. But on general purpose squads, it’s a definite enticement to make sure to put one of each weapon type into the mix. 2 Quote Link to comment Share on other sites More sharing options...
