Ish Posted January 25, 2020 Report Share Posted January 25, 2020 6 minutes ago, Munkie said: And really, in the fluff, how often do we read about deepstrikes mishapping? Usually it's reinforcements showing up Johnny on the spot. I’ve seen it referenced once or twice, but it’s usually in the context of a larger fluff piece about how the “present day” Imperium relies so heavily on ancient technologies that they no longer properly understand and are of questionable reliability... But we don’t need to roll dice to make sure our Imperial Guard Tank Squadron was loaded with petrol and not diesel, right? Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted January 31, 2020 Author Report Share Posted January 31, 2020 Mail day! A few donations for the cause 🙂 2 Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted February 1, 2020 Report Share Posted February 1, 2020 So which Imperial armor do I use for my Custodes? 1 Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted February 3, 2020 Author Report Share Posted February 3, 2020 On 1/31/2020 at 8:19 PM, InfestedKerrigan said: So which Imperial armor do I use for my Custodes? The Warhammer 40,0000: 5th Edition Redux team is always looking for more codices writers! If this was a real project, bringing in some of the newer codicies (Deathwatch, Sisters, Custodes, etc) in line with 5th ed rules and stats would definitely be a long-term goal. Quote Link to comment Share on other sites More sharing options...
Ish Posted February 3, 2020 Report Share Posted February 3, 2020 Luckily, unit stat lines didn’t change much (if at all) from Third through Seventh Edition. So most codices will just need to have special rules tweaked and point values adjusted. This project is doable... It’s insane, sure, but it’s doable. 2 Quote Link to comment Share on other sites More sharing options...
Brother Glacius Posted February 4, 2020 Report Share Posted February 4, 2020 I have to say I never really liked the AP system. It truly made low armor troops fairly useless vs shooting. Never liked that at all. To face the marine stats, you just loaded up on AP3 weapons..you were forced to. How do you fix that? 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted February 4, 2020 Report Share Posted February 4, 2020 It’s been my opinion for years that most of the problems with WH40k and WHFB, across all editions, stems from GW using six-sided dice. This creates a fairly narrow band of possible outcomes and makes the “gap” between results seem a lot bigger than they would be with say, ten-sided dice. No easy fix for this, I’m afraid. On the other hand, a lot of the issues with the Armor save modification system could be fixed rather easily just by tweaking which weapons have AP values... I’d say an across the board reduction of every faction’s basic small arm (boltgun, lasgun, shuriken catapult, etc) by one point of AP would be a good start. 1 Quote Link to comment Share on other sites More sharing options...
Inquisitor66 Posted February 5, 2020 Report Share Posted February 5, 2020 3 hours ago, Ish said: On the other hand, a lot of the issues with the Armor save modification system could be fixed rather easily just by tweaking which weapons have AP values... I’d say an across the board reduction of every faction’s basic small arm (boltgun, lasgun, shuriken catapult, etc) by one point of AP would be a good start. I agree with this completely, in fact this is one of my head rules for improving 8th edition without much upending of rules 1 Quote Link to comment Share on other sites More sharing options...
Munkie Posted February 5, 2020 Report Share Posted February 5, 2020 3 hours ago, Ish said: On the other hand, a lot of the issues with the Armor save modification system could be fixed rather easily just by tweaking which weapons have AP values... I’d say an across the board reduction of every faction’s basic small arm (boltgun, lasgun, shuriken catapult, etc) by one point of AP would be a good start. I'm not sure I fully understand this. To clarify, you'd be advocating a 5th edition AP system, but slightly worse AP values (i.e. bolters, shurikens, would all be AP 6) to reduce their effectiveness against light troops? Or an 8th edition AP system but with basic weapons having AP -1 to increase their effectiveness? I read it as the former, but this 20 minutes ago, Inquisitor66 said: I agree with this completely, in fact this is one of my head rules for improving 8th edition without much upending of rules implies the latter. I'm a confuzzled munkie... Quote Link to comment Share on other sites More sharing options...
Inquisitor66 Posted February 5, 2020 Report Share Posted February 5, 2020 36 minutes ago, Munkie said: I'm not sure I fully understand this. To clarify, you'd be advocating a 5th edition AP system, but slightly worse AP values (i.e. bolters, shurikens, would all be AP 6) to reduce their effectiveness against light troops? Or an 8th edition AP system but with basic weapons having AP -1 to increase their effectiveness? I read it as the former, but this implies the latter. I'm a confuzzled munkie... I read it as the 8th edition ap... but with ap values universally reduced in effectiveness by 1 point. I.e. bolters and Lasguns become ap +1, meltaguns become ap -3 etc... making save values more important and invul saves less valuable on armored troops Quote Link to comment Share on other sites More sharing options...
Munkie Posted February 5, 2020 Report Share Posted February 5, 2020 Oh interesting, I hadn't thought about adding to saves...hmm. My fear is it would just discourage the use of basic weaponry, and therefore troops. Everything else going down in power would definitely make saves more valuable, but people would shy away from basic troops. Quote Link to comment Share on other sites More sharing options...
Ish Posted February 5, 2020 Report Share Posted February 5, 2020 I meant the 8th Edition style armor save reductions, but with the values for most basic and special weapons reduced in effectiveness. But not universally and not making anything give bonuses. My thinking is that the standard-issue, man-portable weapons like boltguns and pulse rifles shouldn’t be piercing the armor of the standard-issue infantryman... Boltguns would remain AP 0, but Bolt Rifles would go from AP -1 to AP 0, etc. This was just a passing thought, I haven’t sat down and evaluated all 24,601 weapons in the game to work out the specifics. (As for making Troops viable, my gut instinct is to go back to the days of only allowing Troops to score.) 1 Quote Link to comment Share on other sites More sharing options...
WestRider Posted February 5, 2020 Report Share Posted February 5, 2020 On 2/4/2020 at 1:11 PM, Ish said: It’s been my opinion for years that most of the problems with WH40k and WHFB, across all editions, stems from GW using six-sided dice. This creates a fairly narrow band of possible outcomes and makes the “gap” between results seem a lot bigger than they would be with say, ten-sided dice. No easy fix for this, I’m afraid. Way back when, I started doing some conversion work for "Warhammer 4d10". I think I might still have those notebooks around. Using the new Apocalypse system as a base for a d12 version might also have potential. The biggest practical issue is that it's more awkward and expensive to get d10s or d12s in the kinds of numbers required than it is for d6s. Quote Link to comment Share on other sites More sharing options...
Ish Posted February 5, 2020 Report Share Posted February 5, 2020 You’d need to change the underlying mechanics more than just swapping D6’s for D10’s... Probably something so that total unit size affected the number of dice rolled. So, like, a full ten-man squad might throw 5d6, but drop down to 3d6, then 2d6, then 1d6 as they take a casualties... 1 Quote Link to comment Share on other sites More sharing options...
Munkie Posted February 6, 2020 Report Share Posted February 6, 2020 On 2/4/2020 at 8:49 PM, Ish said: (As for making Troops viable, my gut instinct is to go back to the days of only allowing Troops to score.) With mission specific ones where heavy support/fast attack/elites are scoring, but give up a bonus point if killed. 2 Quote Link to comment Share on other sites More sharing options...
Ish Posted February 6, 2020 Report Share Posted February 6, 2020 And some sort of special rules in place to allow those armies where it’s thematically appropriate to make some other units to either count as scoring (e.g., White Scars Bike Squads). 2 Quote Link to comment Share on other sites More sharing options...
WestRider Posted February 6, 2020 Report Share Posted February 6, 2020 1 hour ago, Ish said: And some sort of special rules in place to allow those armies where it’s thematically appropriate to make some other units to either count as scoring (e.g., White Scars Bike Squads). 30K actually does this fairly nicely with their Rites of War, which let you break the FOC in various ways (and/or allow normally non-Scoring Units to Score), at the cost of having to abide by restrictions in other places. As with so many other things, the details are where the balance issues show up, but the basic concept is a pretty good one. Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted February 6, 2020 Author Report Share Posted February 6, 2020 14 hours ago, Ish said: And some sort of special rules in place to allow those armies where it’s thematically appropriate to make some other units to either count as scoring (e.g., White Scars Bike Squads). One of the things I really DO like about 8th ed Space Marines (and CSM) is the bringing back of Chapter Tactics. I could totally see doing something like that for a 5th Ed redux, where taking a chapter like White Scars unlocks Bikers as troops, or taking Iron Warriors gives you an extra heavy support slot, etc. Quote Link to comment Share on other sites More sharing options...
Ish Posted February 6, 2020 Report Share Posted February 6, 2020 I think it was the Fourth Edition Codex: Space Marines that has the “pick your own” chapter traits system. They had preselected options for the official Chapters, but it allowed a lot of great personalization for players’ own creations. I do like the way the current system allows for the otherwise “vanilla” Chapters to all feel and play quite distinctly different from each other. But I do miss the way the Fourth Edition codex encouraged original creations. 2 Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted May 22, 2020 Author Report Share Posted May 22, 2020 I initially decided this was something that I wasn't actually going to work on, given that A.) Who has the time?, and B.) Who really cares? However, despite continuing to tell myself this, the idea seems like it won't get out of my head. SO, I've started to write stuff down, even if it's just for my own satisfaction. Daemons seemed (to me) like a relatively straight-forward fix, probably because it was one of the books I actively played in 5th ed (along with CSM). Although it might be that the units that were released after 5th edition could be written into the book as well, but that seems to be a more intensive task that I might revisit at some point. Link to what I currently have done and what I'm working on, for those interested: https://drive.google.com/open?id=1ow9ehhl7zxflALFGx1mNOfdE3iiwZpau 1 Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted May 26, 2020 Author Report Share Posted May 26, 2020 Mail day! 1 Quote Link to comment Share on other sites More sharing options...
peter.cosgrove Posted June 7, 2020 Report Share Posted June 7, 2020 Sooooo, I am pretty much a dis-interested bystander, this isn't something I would be looking at playing, BUT... How much of the Blood Angels codex are you going to throw out? -Descent of Angels -Assault Marines with 2 melta's as troop choice. -Vehicle Pen chart with insta kill for melta's on 5's. -Deep Striking Land Raiders. -Entire force in reserve until turn 2 -Power weapons/Storm Shields for 5 points. -Vanguard Veteran Charge on deep strike. -Blood Lance Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted June 7, 2020 Author Report Share Posted June 7, 2020 35 minutes ago, peter.cosgrove said: Sooooo, I am pretty much a dis-interested bystander, this isn't something I would be looking at playing, BUT... How much of the Blood Angels codex are you going to throw out? -Descent of Angels -Assault Marines with 2 melta's as troop choice. -Vehicle Pen chart with insta kill for melta's on 5's. -Deep Striking Land Raiders. -Entire force in reserve until turn 2 -Power weapons/Storm Shields for 5 points. -Vanguard Veteran Charge on deep strike. -Blood Lance Honestly, I'm not really sure. I never played with or against Blood Angels, so I'd have to take a look through their codex. At the very least I was thinking that their Assault Marines should be in line with the regular SM Assault Marines, save for the BA special rules and maybe BA only weapons like Inferno Pistols, but I'd have to do a side by side comparison. ...If I ever get around to it, or advance the project any further than it is, heh. Quote Link to comment Share on other sites More sharing options...
peter.cosgrove Posted June 7, 2020 Report Share Posted June 7, 2020 In 5th Edition the BA assault marines are troop choices, not fast attack and can take 2 meltaguns in a 5 model unit, Jump pack models only scatter 1d6 instead of 2d6 (Descent of Angels), BA Land Raiders can deep strike, BA units reroll their reserve rolls if they fail (upgrades a 50% to 75% chance to come in on deep strike on turn 2), 5th Edition you can have your entire force in reserve and you don't auto lose if no models are on the board at the end of the battle round, BA Vanguard Veterans can assault on the turn they deep strike, etc etc. 1 Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted June 8, 2020 Author Report Share Posted June 8, 2020 Ok, I had a little time to look over the books, these would be some initial ideas for the codex, keeping in mind that Blood Angels was one of the codicies that I was under the impression would need to be toned down (Grey Knights / Long Fangs, I'm looking at YOU as well): On 6/6/2020 at 6:58 PM, peter.cosgrove said: -Descent of AngelsInitial reaction is to remove the -1d6 to scatter. -Assault Marines with 2 melta's as troop choice.Ideas I have for this would be something like: Sarge can take Inferno Pistol, can take 1 melta per 10 troops, or remove the meltas totally but keep in Inferno Pistol. -Vehicle Pen chart with insta kill for melta's on 5's.5th saw a LOT of parking lot / transport spam lists. I'm ok with keeping the chart as is, or doing something to make the chart more lethal, but I'm not sure what that would look like. -Deep Striking Land Raiders.That would go. -Entire force in reserve until turn 2That per the rules, not per Blood Angels, yeah? But BA can capitalize on it more with DoA. Probably would have to revisit this. -Power weapons/Storm Shields for 5 points.Who does? I went through the BA codex, couldn't find who gets these options for 5 points. -Vanguard Veteran Charge on deep strike.Remove charge from Deep Strike, probably give them the -1d6 scatter. -Blood Lance24", single target psychic power? Quote Link to comment Share on other sites More sharing options...
