scottshoemaker Posted July 24, 2020 Report Share Posted July 24, 2020 Yes, finally starting. The campaign will be fast and loose to accommodate our collective situation. All warbands are welcome. No allies or mercenaries. posting of results of each battle along with a short narrative encouraged. More details to come. Post here with name and warband.Games are not limited to the clubhouse. Quote Link to comment Share on other sites More sharing options...
scottshoemaker Posted July 24, 2020 Author Report Share Posted July 24, 2020 Scott Shoemaker-Iron Golems Quote Link to comment Share on other sites More sharing options...
Inquisitor66 Posted July 24, 2020 Report Share Posted July 24, 2020 48 minutes ago, scottshoemaker said: Scott Shoemaker-Iron Golems Can you give a run down on how campaigns work in Warcry? I'll probably be down to participate with my unmade. Quote Link to comment Share on other sites More sharing options...
Ish Posted July 24, 2020 Report Share Posted July 24, 2020 Ish - Ironjawz Quote Link to comment Share on other sites More sharing options...
Lyraeus Posted July 24, 2020 Report Share Posted July 24, 2020 Lyraeus - Ossiarch Bonereapers Bear with me I have not played before so I will need to get a test game in or two prior Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 25, 2020 Report Share Posted July 25, 2020 23 hours ago, Lyraeus said: Lyraeus - Ossiarch Bonereapers Bear with me But...but...he said no allies. You can't have a bear with you! 😉 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted July 26, 2020 Report Share Posted July 26, 2020 What if it’s an Undead Bear? 1 Quote Link to comment Share on other sites More sharing options...
scottshoemaker Posted July 26, 2020 Author Report Share Posted July 26, 2020 As this is the first campaign, we will be using the Core Campaign Rules. At the heart of every Warcry campaign is the quest your warband is striving to achieve. This is referred to as a campaign quest. You can find a whole array of different campaign quests to choose from in the campaign section of the core book. Each campaign quest has one or more faction runemarks to denote which warbands can embark upon it. After choosing a campaign quest, you will need to fill out a warband roster. https://www.warhammer-community.com/wp-content/uploads/2019/08/Warcry-Warband-Roster.pdf Before your first campaign battle, you can add up to 20 fighters to your warband roster. These fighters can total any number of points, but it should contain at least 1000 points’ worth of fighters to allow you to field a full warband during your first campaign battle. You do not have to add the full 20 fighters to begin with – you can instead choose to add additional fighters as the campaign progresses. You’ll be able to add and remove fighters from your warband roster after each campaign battle (pg 67). When adding fighters to your warband roster, you must adhere to the following restrictions: 1. Your warband roster must include at least 3 fighters. 2. Your warband roster cannot exceed 20 fighters. 3. All fighters added to your warband roster must share the same faction runemark as the campaign quest you have chosen. 4. There can be only 1 fighter added to your warband roster with the Leader runemark. The warband roster includes a campaign progress tracker. This tracks how close your warband is to completing the goal of their quest. There are 12 points on the campaign tracker referred to as map points. Your warband begins on the map point labelled ‘Start’. You can indicate the progress of your warband by marking the map point they have reached. - When mustering a warband for the battle, all fighters chosen must be taken from your warband roster. - Players may be able to muster more than 1000 points of fighters if they have dominated territory or have spent glory points on reinforcements. Each campaign quest includes three unique campaign battles referred to as convergences. On the campaign progress tracker of your warband roster there are three map points marked as the first convergence, the second convergence and the final convergence. Each of these map points is referred to as a convergence map point, and corresponds to a convergence on your campaign quest. When a player’s warband is on a convergence map point, that warband must play the corresponding convergence and be victorious to advance further along the campaign progress tracker. The next time the player controlling that warband plays a campaign battle, they can ask their opponent if they would like to play through their convergence. Each convergence has unique rules to follow when generating the battleplan. If both players’ warbands are on convergence map points, the players will have to decide which convergence they will play through. Only 1 player’s warband can play through their convergence, even if both warbands are embarked upon the same campaign quest and have reached the same convergence map point. After each campaign battle has ended, both players must complete a series of steps referred to as the aftermath sequence. There are 7 steps in the aftermath sequence. The steps must be completed in order and are as follows: 1. Earn and Spend Glory Points 2. Make Injury Rolls 3. Roll for Destiny Levels 4. Add and Remove Fighters 5. Search for Lesser Artefacts 6. Advance on the Campaign Progress Tracker 7. Earn Artefacts of Power or Command Traits 1 Quote Link to comment Share on other sites More sharing options...
scottshoemaker Posted July 26, 2020 Author Report Share Posted July 26, 2020 To summarize: Make a warband Pick a quest. The 8 warcry warbands have access to multiple quests. All other factions have only one. Fight. Mark progress on the tracker after each battle. Convergence battles must be won to advance. Aftermath sequence. I will put together the Campaign packet that has all the details. You will need your Faction Cards. If you do not have cards let me know. 1 Quote Link to comment Share on other sites More sharing options...
scottshoemaker Posted July 28, 2020 Author Report Share Posted July 28, 2020 I have the Core Campaign rules packet available. Contact me if you’d like it. 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted July 28, 2020 Report Share Posted July 28, 2020 King Orcthur’s Kwestin’ Khanigitz Faction: IronjawzQuest: A Proper Scrap King Orcthur and his Ironjawz Waaagh! smashed its way into the Eightpoints many seasons past, but a few of da King’s Khanigitz got lost on their way back to da big shiny portal that led back to da Kastle. These brave Kwestin’ Khanigitz have come to enjoy life in the Eightpoints well enough; it is a brutal place, filled with deadly monsters to hunt and an endless supply of painted humans to crush beneath their armored boots. Despite the constant, unrelenting violence, the ladz are becoming dangerously bored. So few of the opponents they have krump’d recently have provided any decent entertainment. If they don’t find a proper scrap soon, they might have to start krump’n each other. Klaw Klawbite - Brute Boss with Boss Klaw and Brute Smasha (Leader) [ 250 Points ] Thakko - Brute with Gore-Choppa [ 200 Points ] Rolfur da Mage - Brute with Two Choppa [ 180 Points ] Ravin’ Karvem - Brute with Two Choppa [ 180 Points ] Donjon Masta - Brute with Two Choppa [ 180 Points ] 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted July 28, 2020 Report Share Posted July 28, 2020 The ladz got name-tags now. So youse gitz will know ‘xactly who krumped ya! 1 Quote Link to comment Share on other sites More sharing options...
Brother Glacius Posted July 28, 2020 Report Share Posted July 28, 2020 Anyone have the Gloomspite Gitz cards? apparently you can't just buy the cards. EDIT: apparently you can buy the cards, just not from GW's web site. 😞 Quote Link to comment Share on other sites More sharing options...
ninefinger Posted July 28, 2020 Report Share Posted July 28, 2020 8 minutes ago, Brother Glacius said: Anyone have the Gloomspite Gitz cards? apparently you can't just buy the cards. EDIT: apparently you can buy the cards, just not from GW's web site. 😞 I do have them, they're also in the Tome of Champions book Quote Link to comment Share on other sites More sharing options...
Brother Glacius Posted July 28, 2020 Report Share Posted July 28, 2020 Willing to part with them? Quote Link to comment Share on other sites More sharing options...
Inquisitor66 Posted July 28, 2020 Report Share Posted July 28, 2020 46 minutes ago, Brother Glacius said: Anyone have the Gloomspite Gitz cards? apparently you can't just buy the cards. EDIT: apparently you can buy the cards, just not from GW's web site. 😞 GG still has a bunch of the faction cards, have you checked there? Quote Link to comment Share on other sites More sharing options...
Brother Glacius Posted July 28, 2020 Report Share Posted July 28, 2020 no one local seems to have it. I found it online somewhere and bought it 1 Quote Link to comment Share on other sites More sharing options...
ninefinger Posted July 29, 2020 Report Share Posted July 29, 2020 18 hours ago, Inquisitor66 said: GG still has a bunch of the faction cards, have you checked there? I checked them, they all seem to be the 2nd wave of cards - so all stuff that came out post tome of champions, iirc. Glad you got a pack, brog. I *could* part with mine, but do have the models, etc, and would like to try them a couple more times. Quote Link to comment Share on other sites More sharing options...
Inquisitor66 Posted August 31, 2020 Report Share Posted August 31, 2020 Me and Ish are still doing this, we both made it to the first set battle. Anyone still up for this? 1 Quote Link to comment Share on other sites More sharing options...
ninefinger Posted September 2, 2020 Report Share Posted September 2, 2020 On 8/30/2020 at 7:37 PM, Inquisitor66 said: Me and Ish are still doing this, we both made it to the first set battle. Anyone still up for this? Sorry for bailing before a game last night, I hadn’t realized that was your plan and had mentally shifted gears completely. ive only gotten one gang in with my cypher lords, with a glory level on one dude. I’m definitely down to play next time we’re both at game night. Quote Link to comment Share on other sites More sharing options...
jollyork Posted September 22, 2020 Report Share Posted September 22, 2020 Doesn't look like this campaign was able to get rolling due to COVID, but if anyone is interested in playing (with masks and safe social distancing), please post here. The new White Dwarf has rules for warbands from the Cities of Sigmar, which is the closest roster I've seen to proxy my Mordheim Witch Hunters with, so I'm throwing my capotain into the ring (of 8 Points)! 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted September 22, 2020 Report Share Posted September 22, 2020 I’ve really come to enjoy WarCry and am slowly putting together the bitz to make a second warband to complement my Ironjawz. I’m really intrigued by the Cities of Sigmar finally being added. That’s the faction where GW basically dumped all the old “good(ish) guys” from WHFB: Empire, High Elves, Dark Elves, Wood Elves, Dwarfs, etc. I haven’t read the rules, but according to some forum posts I’ve read elsewhere, it looks like Cities of Sigmar can field the following units in Warcry: Freeguild Champion Marksman w/ Repeater Handgun Freeguild Sergeant Matksman w/ Long Rifle Freeguild Guard w/ Sword and Shield Freeguild Guard w/ Spear Freeguild Guard w/ Halberd Ironbeard w/ Drakefire pistol and Cinderblast bomb Ironbreaker Wildwood Warden Wildwood Ranger Freeguild Greatsword Freeguild Crossbowman Freeguild Handgunner Ironwarden w/ Torpedo Irondrake Captain of the Black Guard Black Guard Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted September 22, 2020 Report Share Posted September 22, 2020 30 minutes ago, Ish said: I’ve really come to enjoy WarCry and am slowly putting together the bitz to make a second warband to complement my Ironjawz. I’m really intrigued by the Cities of Sigmar finally being added. That’s the faction where GW basically dumped all the old “good(ish) guys” from WHFB: Empire, High Elves, Dark Elves, Wood Elves, Dwarfs, etc. I haven’t read the rules, but according to some forum posts I’ve read elsewhere, it looks like Cities of Sigmar can field the following units in Warcry: Freeguild Champion Marksman w/ Repeater Handgun Freeguild Sergeant Matksman w/ Long Rifle Freeguild Guard w/ Sword and Shield Freeguild Guard w/ Spear Freeguild Guard w/ Halberd Ironbeard w/ Drakefire pistol and Cinderblast bomb Ironbreaker Wildwood Warden Wildwood Ranger Freeguild Greatsword Freeguild Crossbowman Freeguild Handgunner Ironwarden w/ Torpedo Irondrake Captain of the Black Guard Black Guard Seems a real shame not to include Corsairs, or any of the HE stuff. Shadow Warriors look perfect (astetics wise) for a skirmish style game. Quote Link to comment Share on other sites More sharing options...
Ish Posted September 22, 2020 Report Share Posted September 22, 2020 Warcry lends itself really well to “counts as,” just as long as the weapons are roughly the same and the models are roughly the same, and everything is readily identifiable, I doubt most people won’t object. Black Ark Corsairs have hand crossbows and swords or paired swords, right? So there’s not really a good match in the Cities of Sigmar list... But the Idoneth Deepkin have Namarati Reavers with swords and shortbows. That’s pretty close. Namarati Thralls have big halberds, which could be decently proxied with Dark Elf Executioners or Black Guard. The various Idoneth eel riders could probably be proxied by Cold One Knights (just pretend it jumps or climbs instead of flying). 1 Quote Link to comment Share on other sites More sharing options...
jollyork Posted September 22, 2020 Report Share Posted September 22, 2020 12 hours ago, Andrewgeddon said: Seems a real shame not to include Corsairs, or any of the HE stuff. Shadow Warriors look perfect (astetics wise) for a skirmish style game. I believe this is because Ish is right about CoS being the dumping ground for all WFB models that didn't make it into redone factions in AoS. Since HE have recently turned into Lumineth, I expect Warcry faction cards for them soon, just like Idoneth have. (sorry if that's already obvious and you're just pining for the old HEs... they are dead-dead-dead now). I do like that CoS has so many has so many unit entries so they can proxy just about anything, and I like that nothing in the list is overpowered, which would make opponents feel like you're proxying just to WAAC. They are pretty ho-hum compared to the stronger Warcry factions. 1 Quote Link to comment Share on other sites More sharing options...
