MexicanNinja Posted June 10, 2014 Report Share Posted June 10, 2014 Does the virtual pivot mean that if you make contact with an enemy unit during the pivot it is considered a charge? Quote Link to comment Share on other sites More sharing options...
Raindog Posted June 11, 2014 Report Share Posted June 11, 2014 Virtual Pivoting is for random movement models only. Quote Link to comment Share on other sites More sharing options...
MexicanNinja Posted June 11, 2014 Author Report Share Posted June 11, 2014 Virtual Pivoting is for random movement models only. Yes, I understand that virtual pivot is only for random movement models. This, again, is why I am asking if they can virtual pivot into combat. Quote Link to comment Share on other sites More sharing options...
Raindog Posted June 17, 2014 Report Share Posted June 17, 2014 You cannot virtual pivot into combat. Quote Link to comment Share on other sites More sharing options...
WarlordGhrom Posted June 17, 2014 Report Share Posted June 17, 2014 You cannot virtual pivot into combat. Please clarify RD as this is different or may cause confusion, from what you posted on the OFCC official rulings regarding Virtual Pivot and Random Movement Quote Link to comment Share on other sites More sharing options...
Drak Posted June 17, 2014 Report Share Posted June 17, 2014 the virtual pivot would allow the random movement unit to essentially ignore the 1" rule during it's pivot. thus keeping the opposing unit from "railroading" it along a straight line. Raindog's clarification keeps the pivoting model from rotating into combat through base contact on it's flank with the intervening enemy unit. which also eliminates the equally confusing "you hit in the flank during your pivot how is that a charge?" situation. Quote Link to comment Share on other sites More sharing options...
Failed Charge Posted June 17, 2014 Report Share Posted June 17, 2014 the virtual pivot would allow the random movement unit to essentially ignore the 1" rule during it's pivot. thus keeping the opposing unit from "railroading" it along a straight line. Raindog's clarification keeps the pivoting model from rotating into combat through base contact on it's flank with the intervening enemy unit. which also eliminates the equally confusing "you hit in the flank during your pivot how is that a charge?" situation. This exactly Quote Link to comment Share on other sites More sharing options...
