Guest Mr. Bigglesworth Posted February 6, 2015 Report Share Posted February 6, 2015 What about which chapter tactic at first was thinking ultra but I don't have a lot of units that would benefit. The raptors for reading would make the bikes mug more flexible. Quote Link to comment Share on other sites More sharing options...
Lord Hanaur Posted February 6, 2015 Report Share Posted February 6, 2015 Thanks. so dropping say two bikes for com relay now means I always have one unit of bikes versus an option of two. That seems like a hard sacrifice. Dropping razor and giving aegis line with cimm would work. I agree the razor just doesn't seem to add anything. Im not sure how hard a thing it is given that you are going to be a very fast and hitty unit. It takes up space. Multicharges against weaker foes is a good way to entrench them. Stronger ones will hold you tigher anyways so net result, all you lose by doing this is some positioning. But you get that bak in a lot of ways with the pod. So... Quote Link to comment Share on other sites More sharing options...
Guest Mr. Bigglesworth Posted February 6, 2015 Report Share Posted February 6, 2015 If I take white scars I won't need to worry about being tied up with hit and run. Two units that can dance circles would be helpful. Quote Link to comment Share on other sites More sharing options...
Lord Hanaur Posted February 6, 2015 Report Share Posted February 6, 2015 If I take white scars I won't need to worry about being tied up with hit and run. Two units that can dance circles would be helpful. White Scars! The answer to every Imperial entanglement. Han Solo was a White Scar, I believe, as well. Quote Link to comment Share on other sites More sharing options...
