Widerstandsnest-61 and KwK Nest - info and photos
barca
Widerstandsnest-61
WN-61
1 88mm Pak in pillbox
1 50mm Pak in concrete emplacement
1 tobruk with an R35 tank turret
2 tobruks with MGs
flamethrowers
cited from:
http://www.6juin1944.com/assaut/omaha/en_defense.php
http://www.omaha-beach.org/The%20Beach/TheBeach.html
https://www.facebook.com/ddaytoursofnormandy/photos/a.669629256416204.1073741867.190817760964025/669629273082869/?type=3&permPage=1
eleven photos, incl Renault turret
FoW Articles at Battlefront:
Push 'em Back
http://www.flamesofwar.com/Default.aspx?tabid=109&art_id=3965
5cm KwK Nest (XBX03)
http://www.flamesofwar.com/hobby.aspx?art_id=2427
http://brooklynwargaming.com/tag/5-cm-kwk-39/
https://www.facebook.com/ddaytoursofnormandy/photos/a.669629256416204.1073741867.190817760964025/669629423082854/
https://www.flickr.com/photos/herbnl/8386533513/
http://www.faehrtensucher.com/normandie-1944/landungsstr%C3%A4nde/omaha-beach-teil-1/
The Colleville exit, only a path, was protected by three pockets of resistance. WN 60 had two 7.5-mm guns, a bunker with a Renault tank turret, four 5-cm grenade launcher and a 2-cm Flak. WN 61 was equipped with a 88-mm cannon and a 5.5-mm gun and Renault tank turret bunkers and 5-cm mortars.
https://books.google.com/books?id=Y68oAwAAQBAJ&pg=PA125&lpg=PA125&dq=Widerstandsnest+61%29&source=bl&ots=zd-8oXgGxm&sig=PSzTIZS5wwJs7O3jj2TE-QHwmXM&hl=en&sa=X&ei=ysIeVeiLFtHdoATfnYCwBg&ved=0CGUQ6AEwDA#v=onepage&q=Widerstandsnest%2061)&f=false
http://www.strijdbewijs.nl/normandie6/noreng6.htm
http://www.atlantikwall-frankreich.de/b04_basse_normandie/s05_omaha/s05_omaha.htm
WN 61
Centrally located on the famous Omaha beach landing of resistance was responsible, together with the further west WN 62 for the high losses of landing here American troops. Equipped was the resistance nest with a 88mm Pak guns, a 5cm KwK and two MG ring stands.
https://books.google.com/books?id=e0XjBAAAQBAJ&pg=PT190&lpg=PT190&dq=Widerstandsnest-61&source=bl&ots=-c8QNJjLjH&sig=O4ytiH-tY_rjDbeHVbayJl9daw4&hl=en&sa=X&ei=ssMeVbCUO4XyoAT5i4LwCA&ved=0CEUQ6AEwBjgK#v=onepage&q=Widerstandsnest-61&f=false
from "Tank Turret Fortifications",
 By Neil Short
ISBN-13: 9781847973672
Publisher: Crowood Press, Limited
http://www.amazon.com/Tank-Turret-Fortifications-Neil-Short/dp/1861266871
http://www.scarybiscuitsstudios.com/2014/06/d25567-citizen-soldiers-in-france.html
http://www.flickriver.com/search/tokina+60+300/recent/
http://boardgamegeek.com/blogpost/16110/great-crusade-part-29-d-day
https://www.gmtgames.com/p-276-combat-commander-battle-pack-3-normandy.aspx
http://gizmodo.com/12-pieces-of-tech-that-turned-the-tide-at-normandy-1577142011
http://boardgamegeek.com/thread/535873/so-what-your-favorite-normandy-scenario
Don't know about the accuarcy of this site, but the images are kewl:
http://www.moddb.com/mods/normandy-1944-european-theater1/images/german-emplacements-pt-2-88cm-pak-43-nest
