InfestedKerrigan Posted August 17, 2015 Report Share Posted August 17, 2015 Anyone have any experience with these and any favorites? Quote Link to comment Share on other sites More sharing options...
dkieft Posted August 17, 2015 Report Share Posted August 17, 2015 Wait you mean like Op-X or Simian? Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted August 17, 2015 Author Report Share Posted August 17, 2015 No, you plug them into your MP3 player, and it broadcasts, but at low power, so your car radio can pick up your MP3 Player. A friend of mine 5 or 6 years ago had one, it's range was about 30-40 feet, so car caravanning, could listen to a "private" shared station. Quote Link to comment Share on other sites More sharing options...
DisruptiveConduct Posted August 17, 2015 Report Share Posted August 17, 2015 They are called FM transmitters http://www.amazon.com/FM-Transmitters-MP3-Player-Accessories/b?ie=UTF8&node=13981621 Have not used one in awhile. They work best where there are fewer radio stations to cause interference. Basically, you pick a station number, plug into the mp3 player, then tune yer radio to that station. Usually works pretty good. Sorry I cannot recommend a brand... 1 Quote Link to comment Share on other sites More sharing options...
Mach_5 Posted August 18, 2015 Report Share Posted August 18, 2015 I've tried a few in the past that were garbage, and one that worked okay. Finding the right radio station to limit interference is key. A friend had one that he had to dangle from his rearview mirror in order for the signal to get to his antenna strong enough. Above all, I'd say find one that you can plug in, you don't want to have to worry about recharging batteries for this thing. 1 Quote Link to comment Share on other sites More sharing options...
ROGRE Posted August 20, 2015 Report Share Posted August 20, 2015 I have used one for years (hope it's not killing me). Some work better than others and it will make you realize just how crowded the FM dial is. I have had the best luck with the ones that have the transmitter in line between the lighter plug and the mp3 player. Weirdly seems to work best the less you hunt for a clearer channel and if you leave for car antenna down. Once you find the sweet spot it is clear as a bell with minimal problems. 2 Quote Link to comment Share on other sites More sharing options...
