pretre Posted October 11, 2017 Report Share Posted October 11, 2017 So the new Astra Militarum codex made me realize that I (and a lot of others) have probably been playing SOB wrong the whole time in 8th edition. So, the way that pretty much everyone I know has played it is an Army Rule that you roll a single D6 at the start of your turn and on a 2+, you get one Act of Faith. However: ABILITIES The following abilities are common to several Adeptus Ministorum units: ACTS OF FAITH Roll a D6 at the start of each of your turns. On a roll of 2+, one unit from your army with the Acts of Faith ability can perform an Act of Faith chosen from the following list. Some abilities may allow you to use more than one Act of Faith in the same turn; when this is the case, a different unit must be chosen to perform each Act of Faith. It appears that the Act of Faith ability is a unit specific ability and is reference on each unit with the Act of Faith ability. So you should be rolling a D6 for EACH unit with this special rule in your army. Thoughts? 1 Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 Nope. Roll a D6 at the start of each of your turns. On a roll of 2+, one unit from your army with the Acts of Faith ability can perform an Act of Faith chosen from the following list. Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 2 minutes ago, InfestedKerrigan said: Nope. No, you don't have thoughts or No, you don't think it works that way. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 Multitasking and hit submit on accident. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 It says single die at beginning, and says target single unit. It does not say roll a die foreach unit and on a 2+ unit gains ability. Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 3 minutes ago, InfestedKerrigan said: It says single die at beginning, and says target single unit. It does not say roll a die foreach unit and on a 2+ unit gains ability. Right, but each unit gets that ability. It's like any other ability where you roll a random effect for each unit with the ability. 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 To compare, Rhinos also get to roll one die per model with the special rule, but their effect only helps that one model. "Self-repair: Roll a D6 at the start of each of your turns; on a 6, this model regains one lost wound." Under your interpretation above, you only get to roll 1D6 no matter how many rhinos you have. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 Your ability and my ability are two different things. Your "ARMY WIDE" ability is "Acts of Faith: at beginning of turn roll d6, on a 2+ a target unit with AoF gains an Act of choice" Rhino is a unit ability that has to be activated. Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 7 minutes ago, InfestedKerrigan said: Your ability and my ability are two different things. Your "ARMY WIDE" ability is "Acts of Faith: at beginning of turn roll d6, on a 2+ a target unit with AoF gains an Act of choice" Rhino is a unit ability that has to be activated. ABILITIES The following abilities are common to several Adeptus Ministorum units: It includes Acts of Faith, Shield of Faith, Zealot, etc. All of which trigger for specific units. Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 To be clear, I don't think that this is the intention (although I wish it was as it hearkens back to the old 'each unit generates faith and anyone can use it' days of SOB) and I'm not going to play it this way without a faq. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 For comparisons sake, how is Shield and Zealot worded? Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 Just now, InfestedKerrigan said: For comparisons sake, how is Shield and Zealot worded? SHIELD OF FAITH Models with the Shield of Faith ability have a 6+ invulnerable save. In addition, units with the Shield of Faith ability can attempt to deny one psychic power in each enemy Psychic phase in the same manner as a PSYKER. However, if they do so, instead of rolling 2D6, only roll a single D6; the psychic power is resisted if the roll is greater than the result of the Psychic test that manifested the power. ZEALOT You can re-roll failed hit rolls for a unit with this ability in a turn in which it charged, made a heroic intervention, or was charged by an enemy unit. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 Yeah, I still stand by my thoughts. Reinforced, really. Those both specify plurality, while Acts specifies singular. Otherwise, your thought is on a 2+, unit A can grant Unit B a buff, so on, correct? Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 Some abilities may allow youto use more than one Act of Faith in the same turn; when this is thecase, a different unit must be chosen to perform each Act of Faith. Also, this. It suggests to me that the norm is a single Act in a turn. The ability to perform multiple acts is abnormal. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted October 11, 2017 Report Share Posted October 11, 2017 Having "AoF" on the unit is the qualifier to being able to be targeted by the successful roll at beginning of turn. Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 I agree that that was probably the intention, but instead they made it work differently by giving that text to each unit. They should have put the 'Acts of Faith' section above the abilities section. Quote Link to comment Share on other sites More sharing options...
pretre Posted October 11, 2017 Author Report Share Posted October 11, 2017 5 minutes ago, InfestedKerrigan said: Some abilities may allow youto use more than one Act of Faith in the same turn; when this is thecase, a different unit must be chosen to perform each Act of Faith. Also, this. It suggests to me that the norm is a single Act in a turn. The ability to perform multiple acts is abnormal. Celestine and the Imagifer's text also tends towards the RAI being one act. Quote Link to comment Share on other sites More sharing options...
