Guest Posted December 15, 2017 Report Share Posted December 15, 2017 On break for 40k for at least until the 20th, since I have some things at home that need doing. But I can photo and post some of the terrain projects I've been working on. I often don't finish projects and I tend to work on lots at the same the time, which are probably related, but I don't like setting the bar high. Current project list: Chaos Bastion (with interior). Khorne Dedicated Plasma Obliterator Guardian Games Billboard Bunker Imperial Shrine Non-ADA compliant mountain Chaos Hellfort Medieval Keep Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Medieval Keep Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Found some earlier pics of the Medieval Keep Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Imperial Shrine Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Guardian Games Billboard Bunker Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Khorne Dedicated Plasma Obliterator Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Guardian Games Billboard Bunker (more recent) Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Chaos Hellfort (Photo of the model in my glass case) Quote Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2017 Report Share Posted December 15, 2017 Non-ADA Compliant Mountain (barely started. This one has a hole at the top where things dropped in come out the mine entrance on the bottom. Yeah, a dice roller!) Quote Link to comment Share on other sites More sharing options...
Guest Posted December 26, 2017 Report Share Posted December 26, 2017 No real progress, but I figured out a plan for that non-ADA accessible mountain. I'm thinking I want a small shrine up there. Was originally going to get a small budda statue, but then I saw one of those Epic Great Unclean Ones, which is the perfect size, so I just need to get one of those (the one I saw wasn't for sale). So the shrine will be a satire/parody of a buddist shrine as seen with a warhammer tint. I plan to make this terrain piece AoS and 40k friendly (unlike that imperial shrine above, which is too techy for AoS). Quote Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2017 Report Share Posted December 29, 2017 Minor progress on the Imperial Shrine. Mostly base coats. Not done. Don't like the bricks. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2018 Report Share Posted August 2, 2018 100% FW barricade model I made: Quote Link to comment Share on other sites More sharing options...
WestRider Posted August 2, 2018 Report Share Posted August 2, 2018 I've got several of the bigger gates from FW kits sitting around for just that purpose. Just need to get around to trimming and painting them :) 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2018 Report Share Posted August 2, 2018 Well, if you bring them to WOW one of these times, could get them painted up (or distributed to people who would paint them up). I've had mine sitting for a while, mostly because I don't play 40k at my home at all, so terrain projects are usually for someone else. Gave this guy to Ian at the Warhammer Store in Hillsboro. Thought he'd get a kick out of it. I have one more that I can find and was planning to give it to WOW when I get around to finishing it. So easy, but doing it is sometimes hard to motivate. I doubt anyone is wondering about the paint, but for the record: Black Spray. Short sides and top are painted grey (but my grey is a mix of white and black which is why the color is somewhat uncertain). Then paint a white triangle on the "center-ish" of each long side. Then leave a black space, then another white bar and so forth. Then it's just a matter of covering the white with yellow and using black or grey to touch up the areas that aren't straight enough for your tastes. Totally imperfect. Quote Link to comment Share on other sites More sharing options...
WestRider Posted August 2, 2018 Report Share Posted August 2, 2018 Bringing stuff to WOW involves going a couple hundred miles out of my way, so I think they're just going to sit in my terrain materials box until I get around to them 😉 1 Quote Link to comment Share on other sites More sharing options...
