VonVilkee Posted June 29, 2014 Report Share Posted June 29, 2014 So finally got around to writing up a couple of datasheets to use these awesome craters! First up, lots of drop Pod craters: If at first you don't succeed... Fluff: Well obviously, some Marines tried a drop pod assault here...whether they succeeded or not, we are fighting once again over the same ground. Composition: 3-5 drop pod or round walker craters. All placed following the same rules as unit coherency. Terrain type:craters (pg109) None of the next three things apply Special rule: scattered plates Any non vehicle model touching a crater receives+1 to its armor save. No save becomes a 5+. Remember no save can be improved beyond a 2+. Fluff: drop pods offer lots of random metal plates designed to survive reentry. These plates happen to be easy to hold up against incoming fire. 2 Quote Link to comment Share on other sites More sharing options...
VonVilkee Posted June 29, 2014 Author Report Share Posted June 29, 2014 Vehicle bone yard Fluff: fighting over the same ground again,and again,and again... Is a time honored tradition in war; you happen to be participating in it at this moment. Composition: 2-6 vehicle craters placed following the rules for vehicle squadron coherency (pg 79) Terrain type: rubble (pg 109) Next three none apply Special rule: parts galore! Any vehicle in contact with a crater gains the "It will not die " USR. (pg 167). If the vehicle already had this rule it may add +1 to its end of turn roll. Flyers must enter hover mode to benefit from this rule. 1 Quote Link to comment Share on other sites More sharing options...
VonVilkee Posted June 29, 2014 Author Report Share Posted June 29, 2014 These follow the template discussed on page 183 of the main book. 1 Quote Link to comment Share on other sites More sharing options...
