scott_birchfield Posted December 15, 2015 Report Share Posted December 15, 2015 Someone please explain the difference with these to me and do you have to change you're models or mix and match the bases in a squad? Link to comment Share on other sites More sharing options...
bunkbess20 Posted December 15, 2015 Report Share Posted December 15, 2015 You don't have to change if you don't want to. The newer models space marines, necron warriors are on the 32 mm bases just a way to throw a kink in the competition. There are several ways to adjust your base sizes, you can leave them the way they are or you can buy the extenders for the current bases, or buy all new 32mm bases break off the current ones and then replace them with the new ones. I myself was going to eventually make the change to all 32 mm bases by using the extenders because they look better to me in my opinion. http://www.ebay.com/itm/32-mm-Hollow-Base-Blanks-for-Basing-and-Re-Basing-25-mm-Gaming-Miniatures-/131669831266?hash=item1ea8222e62:g:IEEAAOSwpDdU8SHT these are the ones that you set your models down into. http://www.ebay.com/itm/50X-25mm-to-32mm-Base-Adapters-for-WH40K-Space-Marine-Miniatures-/111813308822?hash=item1a0897b196:g:alUAAOSwofxUfdwi These are the adapters just some examples of ways to change the bases if you want i just searched 32mm base extenders/adaptors Link to comment Share on other sites More sharing options...
