Guest Posted October 16, 2015 Report Share Posted October 16, 2015 Blighted +1: At the end of the Turn, increase this Condition's value by 1. So, at the end of the turn, the Blighted +1 becomes Blighted +2. At the end of the next turn, does Blighted +2 become Blighted +4? Or rather, does the "1" increase have any relation to the Condition Value? Second Question, Beyond Hamelin and a few others which have abilities which specifically affect blighted models, does the blight actually do anything? Obviously, the above makes it clear that the value will keep getting larger, but it doesn't list any damage or side effects. Or rather, if my opponent can't do anything with blight, should I be concerned if one of my models attains the blighted condition? Quote Link to comment Share on other sites More sharing options...
Mach_5 Posted October 16, 2015 Report Share Posted October 16, 2015 Correct on both, Blighted +1 becomes Blighted +2 etc. It does nothing on its own Quote Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2015 Report Share Posted October 16, 2015 Correct on both, Blighted +1 becomes Blighted +2 etc. It does nothing on its own So, just to be extra clear, blighted for 5 turns would be +1, +2, +4, +8, +16 Or would it be +1, +2, +3, +4, +5...? Quote Link to comment Share on other sites More sharing options...
dkieft Posted October 16, 2015 Report Share Posted October 16, 2015 "Blighted" is a condition. "+#" is the current level of blighted. Each turn, you add on to the blighted level. so 1 to 2, 2 to 3, 3 to 4 etc. You do not double the blighted level each turn. 1 Quote Link to comment Share on other sites More sharing options...
Mach_5 Posted October 17, 2015 Report Share Posted October 17, 2015 What Derk said. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 17, 2015 Report Share Posted October 17, 2015 "Blighted" is a condition. "+#" is the current level of blighted. Each turn, you add on to the blighted level. so 1 to 2, 2 to 3, 3 to 4 etc. You do not double the blighted level each turn. I figured out where I was getting confused. It's the 1 without the + Was thinking it was Blighted +1: At the end of the Turn, increase this Condition's value by +1. But, it is instead Blighted +1: At the end of the Turn, increase this Condition's value by 1. Quote Link to comment Share on other sites More sharing options...
