orkdork Posted September 15, 2015 Report Share Posted September 15, 2015 Hey guys, How do folks typically go about measuring a flight or jump move that goes over something? My understanding is that when flying up onto something, you actually are supposed to measure the diagonal movement. Does this apply when flying over models, even though your landing spot is the same height? What about terrain? If I fly/hop over a Ht 2 fence, do I need to bend my measurement over the fence vertically? Both up and down? Thanks in advance! -Orkdork 1 Quote Link to comment Share on other sites More sharing options...
Mach_5 Posted September 15, 2015 Report Share Posted September 15, 2015 All measurements in malifaux are horizontal only, as the crow flies sort of deal. Never measure at an angle up or a vertical distance for flying models. So if you're at the base of a height 10 building, it only takes a little over an inch (the size of your base) to move to standing on the edge on top. It can certainly be awkward sometimes to measure flying distances across tall terrain, but you can usually get it close enough to both players' satisfaction. Also not that if you're taking two Walk actions, you must be able to legally stop between each movement; you can't land on top of Impassable terrain, for example, even if you're planning to take a second walk action to land on the other side. Quote Link to comment Share on other sites More sharing options...
orkdork Posted September 15, 2015 Author Report Share Posted September 15, 2015 So the 9-1-15 FAQ, you measure vertically for movement: "8) Q: A model with the Incorporeal Ability ignores terrain when it moves. If it is on the ground floor of a building which is 10” tall, can it end its move on top of the building, even if its Wk stat is less than 10, since it ignores the building while moving? Same question for a model with Flight in regards to vertical terrain. A: No. Although measurements in Malifaux are generally made from a top down view, vertical distances are measured while moving a model (see pg. 42 of the rulebook, Movement & Terrain). If the model with Incorporeal ends its move on top of the 10” tall building, it would have moved 10” and, unless it has a Wk of 10 or greater, this is not a legal move. However, if the Incorporeal model has a sufficient Wk stat to complete the move, it would be able to end the move on top of the terrain, ignoring the usual rules for climbing, etc. Flight works similarly, except in the case of Enclosed terrain (see Enclosed terrain, rulebook pg. 60)." What do you think? Quote Link to comment Share on other sites More sharing options...
orkdork Posted September 15, 2015 Author Report Share Posted September 15, 2015 This is weird. The rule is on page 44, and only really talks about climbable terrain. It even implies paying double for vertical movement. Quote Link to comment Share on other sites More sharing options...
Mach_5 Posted September 16, 2015 Report Share Posted September 16, 2015 Lol, shows how much we use buildings and tall terrain up here... ;) So I guess you pay for the vertical distance moved in the case of moving to the top of a building. You wouldn't pay double because you're using flight to get up there, rather than struggling to climb like a ladder or cliff). Oddly I think a model with flight would not measure the vertical distance if it was moving to the other side of the building rather than landing on top, though who knows I could be wrong about that too. Quote Link to comment Share on other sites More sharing options...
Brother Glacius Posted September 16, 2015 Report Share Posted September 16, 2015 Dang, just as I was about to get into Malifaux, oh well, back to Kings of War. Come on everyone.... Quote Link to comment Share on other sites More sharing options...
orkdork Posted September 16, 2015 Author Report Share Posted September 16, 2015 @Mark, Nathan and I are thinking we will just play "add height to movement if you land on it, ignore it if you fly/jump over it." It isn't quite right, and over penalizes the cost, but it is close enough. What do you think? @BroG, organize a KoW and BBQ day and I will come :) 2 Quote Link to comment Share on other sites More sharing options...
Brother Glacius Posted September 16, 2015 Report Share Posted September 16, 2015 I've almost perfected my buffalo/lime/cilantro sauce. I could do another wings and thighs batch and have people over. My son is leaving for school this weekend, so I might even get the garage back soon. Send me some dates that will work. 2 Quote Link to comment Share on other sites More sharing options...
Mach_5 Posted September 16, 2015 Report Share Posted September 16, 2015 Works for me, Micah! 1 Quote Link to comment Share on other sites More sharing options...
