ZeroStride Posted June 24, 2020 Report Share Posted June 24, 2020 I picked up a bunch of bases from Alien Lab in anticipation of Sisters, but ended up making custom bases instead (for reasons which now seem questionable after doing like 50 of them...). I have: 4 packs of 4x 32mm bases 3 packs of 5x 25mm bases 1 50mm base Retail it was $49, but I'd be happy to send them to a good home for cheaper. Say, $35? 1 Quote Link to comment Share on other sites More sharing options...
ZeroStride Posted July 10, 2020 Author Report Share Posted July 10, 2020 Update: Would cheaper help? These are really good bases, and I've ordered bases and other basing bits from the supplier several times as well. $20? These should go to a good home... Quote Link to comment Share on other sites More sharing options...
Brother Glacius Posted July 10, 2020 Report Share Posted July 10, 2020 I was tempted, but honestly, you only have 16 bases that can be used as sisters are now on a 32mm base. If there is something else in the army that uses the 25mm bases, then I might get them. Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted July 10, 2020 Report Share Posted July 10, 2020 9 hours ago, Brother Glacius said: I was tempted, but honestly, you only have 16 bases that can be used as sisters are now on a 32mm base. If there is something else in the army that uses the 25mm bases, then I might get them. Arco-flagellants are on 25s. Quote Link to comment Share on other sites More sharing options...
ZeroStride Posted July 10, 2020 Author Report Share Posted July 10, 2020 Correct. I got that assortment to fully fill out that limited edition box, and then grabbed some extra 25s because of Arcos kind of "just in case". 1 Quote Link to comment Share on other sites More sharing options...
