Psilence Posted December 15, 2014 Report Share Posted December 15, 2014 Moble mid to short range shooting army. Blood angel CAD Hq: librarian Troop: 5 man tac. Grav gun, grav pistols *2. Rhino. Troop: 5 man tac. Grav gun, grav pistols *2. Rhino. Fast: 5 man assault squad. Melta *2, grav pistols *2. Fast: 5 man assault squad. Melta *2, grav pistols *2. Fast: 5 man assault squad. Melta *2, grav pistols *2. Hvy: Baal pred. Heavy bolter sponsons. Hvy: Baal pred. Heavy bolter sponsons. Hvy: Baal pred. Heavy bolter sponsons. Baal strike force (detachment) Hq: librarian Troop: 5 man tac. Grav gun, grav pistols *2. Rhino. Troop: 5 man tac. Grav gun, grav pistols *2. Rhino. Elite: command squad. Melta *3. Drop pod. Hvy: Baal pred. Heavy bolter sponsons. Hvy: Baal pred. 1995. Have to say it... Lots of baals. Grav pistols can interchange with melta/flamer/plasma pistols depending on flavor desired. With 'gun slinger' the sarge can fire both. Thoughts? 3 Quote Link to comment Share on other sites More sharing options...
AbusePuppy Posted December 15, 2014 Report Share Posted December 15, 2014 It's a fair number of guns, but they are all VERY short-ranged. If the other guy goes first and/or deploys back from you then wrecks your transports, you've got basically nothing. Bike armies, Eldar, and similar will simply stay out of your 12" range forever and you'll be hard-pressed to catch them. Why Baal Predators over the normal ones? Your army struggles with anti-tank more than anti-infantry, so AutoLas or TriLas would seem like superior choices. Seems like a bit of a gimmick army, although the use of Gunslinger is cute. If you wanted to go for theme, a Vanguard Veteran squad over the Command Squad can (or at least could and I think still are able) to take two pistols on every single guy, which can be hilarious. Quote Link to comment Share on other sites More sharing options...
PourSpelur Posted December 15, 2014 Report Share Posted December 15, 2014 Seems like a bit of a gimmick army, although the use of Gunslinger is cute. If you wanted to go for theme, a Vanguard Veteran squad over the Command Squad can (or at least could and I think still are able) to take two pistols on every single guy, which can be hilarious. Never before had the idea of Space Marines in cowboy hats crossed my mind... 3 Quote Link to comment Share on other sites More sharing options...
Jayne_Cobbb Posted December 15, 2014 Report Share Posted December 15, 2014 At overboard with the pistols. Delete those and you have so many points. Also, put melts pistols on your melts assault squads. Quote Link to comment Share on other sites More sharing options...
Psilence Posted December 15, 2014 Author Report Share Posted December 15, 2014 @ AP. I agree, certain armies will just dance around it. With so many fast hulls rolling around though, and with significant mid range/str firepower, running forever won't be viable. Baals over regular for volume of fire and army synergy. Everybody wants to get in close. With all the grav/melta on the infantry long ranged preds would be confused. It is very gimmicky. :p basically again just going for volume of fire. I'll have to check the vanguard/command squads. As a sacrificial alpha, more shots would be better. @ jayne. Yeah, a little overkill :p losing the pistols would free up tons of points, but the short ranged output would suffer. melts pistols would focus the assaults defiantly. I guess the only advantage to grav would be the matching 12" range. At this point it's more of a what if/for fun list. Quote Link to comment Share on other sites More sharing options...
George Posted December 15, 2014 Report Share Posted December 15, 2014 I like it. It's very fluffy and would do well at OFCC. 1 Quote Link to comment Share on other sites More sharing options...
