Andrewgeddon Posted July 30, 2015 Report Share Posted July 30, 2015 Hey, not sure I'd this should go here or in Artificer's Forge, but I was wondering if anyone has any tips for removing weapons from the hands of minis and making it look more natural for BB? I've got some Bloodreavers that I drilled the weapons out of their hands, but rather than looking like clenched fists, it just looks like they are making "Os" with their hands... Quote Link to comment Share on other sites More sharing options...
Burk Posted July 30, 2015 Report Share Posted July 30, 2015 dont drill out the whole weapon. Cut them flush, then drill a little bevel down. that way it looks like a clenched fist instead of an "o" 2 Quote Link to comment Share on other sites More sharing options...
Guest Mr. Bigglesworth Posted July 30, 2015 Report Share Posted July 30, 2015 If you drilled through take a second smaller bit and drill out at second second knuckle so looks a little open and slice the thumb free. Or equip with brass knuckles. Quote Link to comment Share on other sites More sharing options...
Andrewgeddon Posted July 30, 2015 Author Report Share Posted July 30, 2015 dont drill out the whole weapon. Cut them flush, then drill a little bevel down. that way it looks like a clenched fist instead of an "o" I tried this, but it just looks like they are holding chunks of weapon handles instead? Maybe I need to mess around with it some more... Quote Link to comment Share on other sites More sharing options...
Burk Posted July 30, 2015 Report Share Posted July 30, 2015 You need the small rounded (ball) dremel bit. that will let you bevel it on the top easily, then cut into the "handle" left over between the fingers and palm. It takes some time to make that smooth so it doesnt look like the handle, but it can be done. Quote Link to comment Share on other sites More sharing options...
jollyork Posted August 1, 2015 Report Share Posted August 1, 2015 Yeah, what they said. Save the thumb on top if you can, and bevel down the weapon handle into a palm. The palm often won't be visible, so it only needs to be a rough shape. The thumb is really what seals the deal in a successful conversion. If you slice it off, which is sometimes unavoidable, it's a pretty easy fix with a spot of green stuff. The other option, of course, is to cut at the wrist and replace with other hand options. I am a growing fan of this because you can get your hands on (ha ha) lots of cool open hands with dynamic poses like zombies and ghouls, or weaponless hands. Quote Link to comment Share on other sites More sharing options...
