generalripphook Posted August 20, 2015 Report Share Posted August 20, 2015 Could you get away with taking a Lemun Russ Chasse and converting it into the tank destroyer? What's the size of the tank destroyer? 1 Quote Link to comment Share on other sites More sharing options...
WestRider Posted August 20, 2015 Report Share Posted August 20, 2015 The Destroyer Tank Hunter is based on the Russ chassis anyhow. All you need is something to cover where the turret would be and a gun for it. 1 Quote Link to comment Share on other sites More sharing options...
generalripphook Posted August 20, 2015 Author Report Share Posted August 20, 2015 The turret is easy because you just put the cover on it for the normal Lemun turret. Same size and everything. The gun....now that's a hard part. Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted August 20, 2015 Report Share Posted August 20, 2015 You couldn't use the Vanquisher Cannon attached to the nose for it? Quote Link to comment Share on other sites More sharing options...
generalripphook Posted August 20, 2015 Author Report Share Posted August 20, 2015 That's what I was thinking about using but I might just take a basilisk barrel and hack it off and use that. I honestly was just conceptualizing it. I ordered two tanks on eBay and will be converting one to a tank destroyer and the other to just look cool. I will probably need to throw some other things on the back and accessories/bling to make it look like a tank that's been hidden for a while and about to pounce I am contemplating flipping the Lemun Russ around for this conversion. So that the back of the tank will be the front. Hmmm Quote Link to comment Share on other sites More sharing options...
VonVilkee Posted August 20, 2015 Report Share Posted August 20, 2015 I've used bases in the past to cap the leman russ chassis. A twenty five milli base glued to the bottom of whatever fits super well. Quote Link to comment Share on other sites More sharing options...
