WestRider Posted July 7, 2014 Report Share Posted July 7, 2014 Chaos Lord, Mark of Khorne, Juggernaut, Axe of Blind Fury, 4++, MeltabombsKharne7 Berzerkers, 2 Chain-Axes, Icon of Wrath, Powerfist2x1 Mutilator, Mark of Khorne5 Spawn, Mark of Khorne3xMaulerFiendLand Raider, Dozer Blade, Destroyer BladesHelfist Mayhem Pack, 3xHelbrute, MM/HF14 Flesh Hounds I've got a couple of ideas for how to make it Battle Forged, but I'd really like to be able to run all three of my MaulerFiend conversions plus the Land Raider full of Berzerkers. And finding a Herald to match my old-school Bloodletters would be a pain, so I'd either have to drop the Khorne Dogs or scrape out a ton of Points to get a DP or Bloodthirster. 4 Quote Link to comment Share on other sites More sharing options...
PourSpelur Posted July 8, 2014 Report Share Posted July 8, 2014 Machines that kill: As a list, no idea. As a themed army, great. As a band name, awesome;) Looks fun and fluffy! Quote Link to comment Share on other sites More sharing options...
pretre Posted July 8, 2014 Report Share Posted July 8, 2014 Looks khorne-y! Perfectly fine for the team event. Also, a good example of unbound not always being 10xawesome unit. 1 Quote Link to comment Share on other sites More sharing options...
magnusthetraitor Posted July 8, 2014 Report Share Posted July 8, 2014 I don't think I can fully express how [big bad swear word]ing metal this list, but if I could it would be in the form of a Metalocalypse song. You are my hero.Thank you.Magnus 1 Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 8, 2014 Author Report Share Posted July 8, 2014 OK, that's the kind of reaction I couldn't even admit to myself I was hoping for :D 1 Quote Link to comment Share on other sites More sharing options...
AbusePuppy Posted July 8, 2014 Report Share Posted July 8, 2014 Chaos Lord, Mark of Khorne, Juggernaut, Axe of Blind Fury, 4++, Meltabombs Kharne 7 Berzerkers, 2 Chain-Axes, Icon of Wrath, Powerfist 2x1 Mutilator, Mark of Khorne 5 Spawn, Mark of Khorne 3xMaulerFiend Land Raider, Dozer Blade, Destroyer Blades Helfist Mayhem Pack, 3xHelbrute, MM/HF 14 Flesh Hounds I've got a couple of ideas for how to make it Battle Forged, but I'd really like to be able to run all three of my MaulerFiend conversions plus the Land Raider full of Berzerkers. And finding a Herald to match my old-school Bloodletters would be a pain, so I'd either have to drop the Khorne Dogs or scrape out a ton of Points to get a DP or Bloodthirster. Discounting the Flesh Hounds, it would actually be quite easy to make this into a Battleforged list- by allying CSM and either Crimson's Laughter or Black Legion, you could get the four HS slots you need. You would need to add two Troop units, however, since currently you only have the one. Dropping the Khorne Dogs, you should have enough points for a unit of ten CSM with MoK, two meltaguns, and a Rhino. (You want to go BP/CCW, natch.) You would then need to scrape up 70pts for a unit of Cultists (presumably with MoK to match your other units), which I would recommend dropping a Mutilator and the Destroyer Blades/Chainaxes for. That might actually be enough points to afford a minimum unit of CSM with MoK, I haven't crunched the numbers exactly. 1 Quote Link to comment Share on other sites More sharing options...
Steel Angel Posted July 8, 2014 Report Share Posted July 8, 2014 Discounting the Flesh Hounds, it would actually be quite easy to make this into a Battleforged list- by allying CSM and either Crimson's Laughter or Black Legion, you could get the four HS slots you need. You would need to add two Troop units, however, since currently you only have the one. Dropping the Khorne Dogs, you should have enough points for a unit of ten CSM with MoK, two meltaguns, and a Rhino. (You want to go BP/CCW, natch.) You would then need to scrape up 70pts for a unit of Cultists (presumably with MoK to match your other units), which I would recommend dropping a Mutilator and the Destroyer Blades/Chainaxes for. That might actually be enough points to afford a minimum unit of CSM with MoK, I haven't crunched the numbers exactly. That list is in the Monty Python expansion right. Sorry couldn't resist. 1 Quote Link to comment Share on other sites More sharing options...
magnusthetraitor Posted July 8, 2014 Report Share Posted July 8, 2014 It doesn't really need to be Battleforged, so why bother? Objective Secured on Berserkers is awesome, but so is a pack of Flesh Hounds leading the charge. Quote Link to comment Share on other sites More sharing options...
pretre Posted July 8, 2014 Report Share Posted July 8, 2014 I mostly figured that that was what he had. Either way is cool though. Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 8, 2014 Author Report Share Posted July 8, 2014 I could do it, yeah, but the other reason I went Unbound is that I find the CSM Troops Choices to mostly be not only lacking, but more importantly, boring, in a list like this. They can work OK in a more balanced or firepower-centric list, or one that's going for a slow grinding assault (zombies), but Assault Units in Rhinos are frustrating, and Culties feel, idk, kinda meta-gamey, like they're just there to fill the requirement and hold Objectives, not something that would actually be keeping up with this mess of bloodthirsty speed freaks. Also, if my Mechano-Spawn Conversions seriously aren't coming along well in the next week or so, I may well swap them out and drop a couple of bits to put in a Hades Helldrake, because that would be more in line with the theme than regular Spawn, and it gives me some semblance of Anti-Air. EDIT: Also just realized, I should totally figure out a way to put a Warpsmith in here. 1 Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 9, 2014 Author Report Share Posted July 9, 2014 Chaos Lord, Mark of Khorne, Juggernaut, Axe of Blind Fury, 4++, MeltabombsKharne Warpsmith, Mark of Khorne, Combi-Melta 6 Berzerkers, 2 Chainaxes, Icon of Wrath, PowerfistHelldrake, Hades Autocannon3xMaulerFiendLand Raider, Dozer Blade, Destroyer BladesHelfist Mayhem Pack, 3xHelbrute, Multi-Meltas, 2 have Heavy Flamer15 Flesh Hounds There we go, got the Warpsmith in, and cuts way down on what I still have to convert/paint. Plus now all the multi-model Units (after ICs have Joined) come to multiples of 8, and I have 8 war machines, and a total model count that's a multiple of 8. Quote Link to comment Share on other sites More sharing options...
pretre Posted July 9, 2014 Report Share Posted July 9, 2014 That's a lot of sacred numbers! Khorne approves! Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 16, 2014 Author Report Share Posted July 16, 2014 Oh, before I get too far into building them, I should probably ask: Does anyone mind if I have my Flesh Hounds on 40mm round bases (like every other 40K Beast Unit I can think of), rather than the 25x50mm square Fantasy bases? I hate the way it looks having some square bases mixed into a 40K Army. Quote Link to comment Share on other sites More sharing options...
Steel Angel Posted July 16, 2014 Report Share Posted July 16, 2014 the new oval biker bases should work fine Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 16, 2014 Author Report Share Posted July 16, 2014 I have a ton of 40mm rounds already, tho, and about half of them are on them. And like I said, I can't think of another 40K Beast Unit that isn't on a 40mm round. Quote Link to comment Share on other sites More sharing options...
pretre Posted July 16, 2014 Report Share Posted July 16, 2014 40mm rounds sound fine to me. That's what fenrisian wolves are on. Quote Link to comment Share on other sites More sharing options...
magnusthetraitor Posted July 16, 2014 Report Share Posted July 16, 2014 My Flesh Hounds (Chaos Hounds for WHFB I think) are on 40mm rounds, and nobody has ever said anything. They look good on that size base. Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 16, 2014 Author Report Share Posted July 16, 2014 Cool. I really do prefer them on those bases. Quote Link to comment Share on other sites More sharing options...
fluger Posted July 17, 2014 Report Share Posted July 17, 2014 This is the kind of list that Unbound was made for. 1 Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 20, 2014 Author Report Share Posted July 20, 2014 Sneak preview: The Shepherd and his Flock: 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted July 20, 2014 Report Share Posted July 20, 2014 Closer pic of the warpsmith? Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 21, 2014 Author Report Share Posted July 21, 2014 Once he's done. That's why it's a "preview" ;) Also I need to find the cord for my real camera :P Quote Link to comment Share on other sites More sharing options...
pretre Posted July 21, 2014 Report Share Posted July 21, 2014 EXCUSES! KHORNE DOES NOT ALLOW EXC... Oh I do? CARRY ON! Quote Link to comment Share on other sites More sharing options...
WestRider Posted July 22, 2014 Author Report Share Posted July 22, 2014 Got a chance to play this Sunday. I dropped the Helldrake for some Spawn because I realized that the Daemon Rules don't let the Chaos Lord Join the Khorne Dogs*. Lost 9-11 to a moderately solid UM force, but it was still a fun game, and despite a bad Turn 2 (I put too much priority on screening the Land Raider from his Podded Units, and that left some of my guys with overly-long Charges. Which they failed.), I was in it until things really fell apart on Turn 6. The low Unit/Model count, combined with the high speed and short range means that it plays really fast, which I really like, and it's quick to get to the point where I'm punching stuff in the face :D Also, good lord Land Raiders are tough now. *This also, I think, makes it a bit easier to match up, since there's more of the Army that basic Weapons can hurt instead of all the Bolter dudes just sitting there staring at a wall of AV12. Quote Link to comment Share on other sites More sharing options...
pretre Posted July 22, 2014 Report Share Posted July 22, 2014 Did you guys play Maelstrom or normal? Quote Link to comment Share on other sites More sharing options...
