fluger Posted June 26, 2014 Report Share Posted June 26, 2014 I love the dice animations. Orks with Hammer of Wrath is pretty funny. 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 26, 2014 Author Report Share Posted June 26, 2014 Just an FYI for anyone going digital. Apparently, multiple people are saying the preorder is available for immediate download through Black Library today. Quote Link to comment Share on other sites More sharing options...
jollyork Posted June 26, 2014 Report Share Posted June 26, 2014 Bummer about Deff Rollas. They always were too good to be true, but it's sad to see them drop so hard. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 27, 2014 Author Report Share Posted June 27, 2014 1 Quote Link to comment Share on other sites More sharing options...
fluger Posted June 27, 2014 Report Share Posted June 27, 2014 Wow, lobbas are *cheaper*. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 27, 2014 Author Report Share Posted June 27, 2014 So, since our codex has arrived early due to GW's very own Mek technology shooting the codex into close combat, it's finally time to have a look at what changed for us orks from 6th edition:7th Edition: 1) Shooting- (Combi-)Skorchas no longer shoot at the same time as burnaz, potentially leaving either out of range to hurt anything.- Focus fire is gone. Putting half your mob in cover is no longer a disadvantage.- Artillery can move and shoot.2) Assault- You can now charge vehicles and monstrous creatures you can't hurt- You can move through space smaller than your base while charging- Charging through difficult terrain is -2"- 'urty syringe only gives a reroll if your strength is higher than target3) Characters- When a character overkills is opponent in a challenge, the excess wounds are allocated to the unit. No more sergeants taking one for the team- When the unit has no one left to fight, they will pile in the challenge and can allocate wounds to the challenge. No more characters stalling a mob of boyz for one turn by challenging the nob- Any character can be your warlord- New warlord tables, some pretty useful for orks4) Vehicles- Rams no longer take distance traveled into account, but gain +1S from reinforced ram's +2AV- Vehicle explosions are S4 for everyone, inside and outside- Can't explode vehicles without AP2/1 unless open topped- Passengers of open-topped vehicles now suffer hits from template weapons- Deff dreads and Killa Kanz got Hammer of Wrath5) List-building- Can take any number of detachments with at least 1 HQ and two troops- Lost Tau, Necrons, and Imperial Guard as allies of convenience- Can now ally "come the apocalypse" factions Codex: Orks:faction-wide special rules - Kept Furious charge- Need Warboss to call Waaagh!- Waaagh! goes back to allowing running and charging during the same turn- Waaagh! is now called before rolling for reserves- Got 'ere we go, which allows to reroll one charge dice. All orks have 'ere we go- Mob rule changed: On a failed moral or pinning test roll D6 instead:1 Born to Fight: If in combat, pass, otherwise fail2-3 Breaking Heads: If character in unit, pass and take d6 S4 hits, otherwise fail. Wounds cannot be allocated to ork characters (wounds disappear if only characters are left)4-6 Squabble: If 10 or more orks in unit, pass and take d6 S4 hits, otherwise fail- Orks can choose to use a detachment with 3 HQ 9 Troops 3 FA 3 Elite 3 HS 1 LoW 1 Fortification instead of the normal one. If they do 1 HQ and 3 Troops are mandatory. Units of 10 or more models that roll 10" or more on the charge have Hammer of Wrath. No objective secured.- Formation requiring exactly 6 Boyz mobs, 1 unit of Nobz, 1 unit of Gretchin, 1 mek and a Warboss allows for unlimited Waaaghs! Has Hammer of Wrath rule above as well Ork psychic powers Primaris: Frazzle, 24" S6 AP3 blast witchfire (1 WC)1: 'ead banger, 24" focused witchfire, causes wound on failed T test with no cover or armor saves allowed (1 WC)2: Warpath, same as before (1 WC)3: Da jump, same as previous 'ere we go. When you roll doubles for scatter, entire unit must snap-fire (1 WC)4: Kill bolt, 18" S10 AP 2 beam (2 WC)5: Power Vomit: S7 AP2 template (2 WC)6: Da Krunch: S2D6 AP4 Large Blast, Barrage, if you roll a over 10 you get another one until you roll 10 or under, or everything is dead. (2 WC) Ork warlord trait 1 Prophet of the Waaagh!: The Warlord gains the Waaagh! special rule. If the Warlord already has the Waaagh! special rule then, in addition to the usual effects, all friendly models with the ’Ere We Go! special rule gain the Fearless special rule when he calls a Waaagh!, until the start of their next turn.2 Bellowing Tyrant: The Warlord, and all friendly units with the Orks Faction within 12″ of him, re-roll failed Morale checks and Pinning tests.3 Like a Thunderbolt!: The Warlord, and all friendly units with the Orks Faction within 12″ of him, can re-roll all the dice when determining Run moves or charge range.4 Brutal but Kunnin’: The Warlord can re-roll one failed To Hit or To Wound roll each turn.5 Kunnin’ but Brutal: The Warlord can re-roll one failed armour or invulnerable saving throw each turn.6 Might is Right: The Warlord receives +1 to the Strength characteristic on his profile. Additional Malstrom Missions If your Warlord has the Orks Faction, these Tactical Objectives replace the Capture & Control Tactical Objectives (numbers 11-16) described in Warhammer 40,000: The Rules.- Shoot an enemy unit off the board,- Kill the an enemy in a challenge with your warlord (d3 VP if you kill the enemy warlord)- Destroy an enemy unit in your assault phase (more units gone, more points)- Three units must turbo boost, move flat out, ram or run 6" or more (6" only for running, any distance for athers).- Secure a random objective (roll a D6 when drawing the card),- Charge more than 10 inches. HQ - Warboss no longer makes Nobz troops- Warboss now calls the Waaagh!- Big Mek no longer makes Deff Dreads troops- Big Mek can now take MA and KFF or MA and Tellyporta-Blasta (short range S8 Ap2 blast, instant death/auto pen on sixes)- Big Mek can now take Bike and KFF or Bike and SAG- Big Mek may take a killsaw- Big Mek gets a KMB instead of a TL shoota when switching to MA- Weirdboy and Warphead upgrade dropped in price- Weirdboy no longer randomly cast powers- Weirdboy may generate powers from Sanctic Demonology, Malific Demonology and Power of the Waaagh!.- Weirdboy has force staff (+2S AP4)- Weirdboy generate an extra warp charge if at least 10 orks nearby. When he does and fails to manifest a power he takes a S2 hit, no saves allowed- Mad Doc Grotznik gives Fearless, Rampage and FNP- New! Able to field a regular mek for every HQ chosen, takes no slot. May join infantry or artillery units. Meks can still be taken as part of Burna/Loota units- Meks can take Kill Saw, KMB, Kustom Mega Slugga, Rokkit, Kombi weapons and grot oilers- Mek tools fix vehicles on a 5+ but no longer shake vehicles- New! Able to field a painboy as HQ- Pain boy can take boss pole, warbike, grot orderly and attack squig- New! Badrukk is now a HQ choice, small drop in points- Badrukk has the Kunnin’ but Brutal Warlord trait- New! Zagstruk is now a HQ choice- Zagstruk has the Bellowing Tyrant Warlord trait- Zagstruk causes S8 AP2 Hammer of Wrath attacks- Zagstruk no longer allows his unit to assault after deep strike- Zagstruk no longer executes his unit- Wazzdakka is gone. Fluff claims he has left with his own Waaagh! of bikers.- Ol' Zogwort is gone. Fluff claims he has left with his own Waaagh! of mad- and weirdboyz. Elite - Mega-Armoured Nobz have the option to take a pair of killsaws (Powerklaw with armour bane)- Mega-Armoured Nobz may take boss poles.- Mega-Armoured Nobz are bulky- Nobz slightly cheaper, bike upgrade more expensive, so biker nobz are the same as before- Nobz can buy 'eavy armor for less points- Nobz lost the ability to purchase painboyz or cybork- All units (including nobz) are now lead by a boss nobz, same stats but character- Tank bustaz got a small price drop- Tank bustaz are no longer limited in their target choices. Instead, Glory Hogs gives an additional VP if they score first blood by killing a vehicle- Tank bustaz' tank hammers are S8 AP3 unwieldy but costs 15 points now- Tank bustaz' bomb squigs are now AP4 and no longer hit own vehicles- Tankbusta bombs have become Meltabombs.- Tank bustaz may take Trukks as dedicated transports- Tank bustaz get the tankhunter special rule- Tank busta nob can no longer take tank hammers, and gets now discount on his klaw.- Burna boyz are slightly more expensive- Burna boyz may take Trukks as dedicated transports- Meks from Burna units get a discount on their killsaw- Kommandoz got a price drop- Kommandoz gained Stealth- Kommandoz can have Nob and Snikrot- Snikrot can be fielded solo, or joined to a unit of Kommandoz- Snikrot's has fear, can still arrive from any board edge, his shroud replaces stealth- Snikrot does not take up a force organisation slot if you have any Kommandoz at all (does not need to join them).- Snikrot can no longer enter the table from the opponent's edge- Snikrot and his unit gain the Shrouded USR on the turn he arrives or is deployed, but it replaces their stealth.- All Elite choices have stikkbombs Troops - Nobz leading boyz may take combi-shootaz- Boy Nobz leading boyz can only get 'eavy armor if entire mob is upgraded- Boy Nobz cannot gain one of the special weapons, but may buy combi-shootaz- Slugga boyz have gained stikk bombs for free- Shoota boyz have gained stikk bombs and have increase by one point per model- No limit on units you can upgrade to 'ard boyz- Boyz get rokkit for 5 points less- Gretchin dropped in points- Grot pod may now choose to make one attack at double strength- Squighound causes d3 S3 hits on the gretchin rather than outright eating thems Fast Attack - Dakkajets, Burna bommers and Blitza bommers only fire one additional shot with their assault guns during a Waaagh!- Bitza bommers bombs are now S7 AP2 large blast, armorbane- Blitza bommers shoot rear armor on their 10-12 result when dropping a bomb- Deff koptaz 5 points cheaper- Deff koptaz no longer need to pay points for their ranged weapon upgrades- Storm boyz have dropped in price- Storm boyz can now be fielded in units of 30- Storm boyz can now use their jump packs to run 2d6 in addition to moving 12". If they do, they take dangerous terrain tests.- Storm boyz can benefit from the Waaagh!- Warbikers got a massive price drop to 18 per bike- Warbikers can be fielded in units of 15- Warbikers no longer get 4+ cover. Instead, they gain +1 cover while turbo-boosting- Buggies 5 points cheaper- Buggies can be taken in units of 5- Buggies can gaine the Outflank USR- New! Trukk can be chosen as fast attack choice- Trukk dropped in price- Trukk upgrade to Rokkit now free- Trukk rule "Ramshackle" downgrades penetrating hits to glancing hits on a 6+- No more size limit on units to buy trukk Heavy Support - Killa Kanz have gone up in price per model, but weapon upgrades are cheaper. Kan with rokkits is the same as before, kan with grotzooka is 5 points more.- Killa Kanz can now have up to 6 walkers per unit- Killa Kanz must roll a d6 after losing more than 25% of their unit. If they roll 1 or 2, the entire unit is shaken. Panic roll is increased by +1 for every 3 kanz or 1 deff dread nearby.- Killa Kanz get Grot Riggers for 5 points per model- Killa Kanz get a Kan Klaw instead of a DCCW, being +2S AP2.- Deff Dread and its options have become a little cheaper (100 points for all-klaw dread)- Deff Dreads now use power klaws instead of DCCW (no functional change)- Deff Dreads now get an additional attack from their first pair of PKs- Deff Dreads get Grot Riggers for 10 points- Zzap gunz now roll a d6 on strength 11 and 12. On a 1-3 it Get's Hot!- Battlewagon has gone up in price- Battlewagon can upgrade to killkannon for half the old price- Battlewagons can get grot riggers for 10 points- Flash Gits had a small price drop- Flash Gits' snazz guns trippled their shots- Flash Gits no longer have any upgrades but ammo runts- Flash Gits may take battlewagons as dedicated transports- Flash Gits now have Boss Poles instead of 'eavy armor- Flash Gits are lead by a Kaptin, same stats but character- New! Lootaz now in heavy support- Lootaz got a small price drop- Lootaz may have a trukk as dedicated transport- New! Gorkanaut AV13/13/12 Walker- Gorkanaut has a S6 AP4 Assault 3d6 weapon, two rokkits, skorcha and a TL big shoota.- Gorkanaut has rampage- New! Morkanaut AV13/13/12 Walker- Morkanaut has a S8 AP2 small blast weapon, two rokkits, a KMB and a TL big shoota- Morkanaut can take a KFF- Both walkers have a Klaw of Gork (or Mork), which is S10 AP1 concussive- Both walkers can take Gort Riggers for 20 points- New! Mek Gunz combine old big gunz entry and four new artillery guns- Mek Gunz may have up to five gunz per battery each with up to four gretchin- Mek Gunz cannot take runtherds- Kannon, Lobba and Zzap gun got price drops- Bubblechukka is large blast and rolls one d6 for both strength and AP- Smasha gun is S4+d6 AP1- Kustom Mega-Kannon is S8 AP2 small blast, Get's Hot!- Traktor-Kannon is S8 AP3 Skyfire and automatically immobilizes fliers when at least glancing them. FMC get -3 to their grounding check.- Zzap gun got Get's hot! and has a 50% chance of getting hot again when strength is above 10. Still shakes on glances and pens.- Each Mek Gun determines their random rolls by itself. So five zzap guns, 5x 2d6 for strength- Looted wagon has been removed from the codex, readded by White Dwarf- Looted wagons had a massive price drop- Looted wagons' "Don't press dat." is now rolled in the shooting phase and forces you to move flat out. No longer prevents disembarking.- Looted wagon can no longer take boom gunz, option for killkannon instead Lords of War - Ghazghkull Thrakka is now a Lord of War- Can take attack squig and ammo runts.- Lost +2 attacks on the charge from Adamantium Skull, gets Eternal Warrior and Cybork instead- Thrakka no longer give 6" runs on his Waaagh!- Instead, MA models in his unit (including him) may run during that turn- Give flat 2+ invul until next turn- Can no longer call the Waaagh! at any time- Stompa is in the codex- Stompa can take Grot Riggers and extra Supa-Rokkits Wargear - KFF is now a 5++ save against shooting for models within 6" (not units!). While embarked, only the transport gets the save, no extending bubble, no protection from flamers or explosions for the passenger- SAG :one: :one: only kills the Mek now, no one else- SAG :six: :six: is Vortex, which causes the large blast to become destroyer and to jump every shooting phase until you roll double.- Big Choppa is AP5- Cybork is 6+ FNP now, no invul, doesn't stack with painboyz- Git Findas give +1 BS when model remained stationary. Available to all HQs- Attack Squig gives one reroll to hit per combat- Boss pole: Each time a unit that includes at least one model with a Bosspole rolls on the Mob Rule table, you may choose to re-roll any result other than a Breaking Heads(2-3) result. You must accept the result of the re-roll- Waaagh! Banner went up in price, still nobz only- New! Kustom Mega Sluggas for Meks: S8 AP2 Get's Hot! Pistol Vehicle Upgrades - Red Paint now only increases Flat Out moves- Deff Rollas are d3 S10 AP4 hits only when DoG is faile now. Also increases front armor by 2 while ramming. Dropped price by half.- Wrecking ball is 3" S9 AP4 Assault D3 now- Grot Riggers provide the IWND USR to vehicles- Boarding planks add +2" to charge when charging from an open-topped vehicle- Grabbin Klaw can no longer grab skimmers Relics - Ded shiny shoota is a 6 shots twin-linked shoota, rolls of 1 hit one of your own units within 6", can't hit own unit or self.- Warboss Gazbag’s Blitzbike has a twin-linked S6 AP3 Assault 3 gun on it and can turbo-boost 18"- Hedwompas choppa is a +2 str, AP5, rending choppa that beheads on a roll of 6 (insta death).- Da Finkin Kap gives your warlord an additional trait from the strategic list in the BRB.- Lucky Stixx is a Waaagh! banner for +1 WS. In addition the user can choose to reroll any failed to hit, to wound or saving throws they make. If they fail 3 of these rerolls in a single turn they are removed as a casualty.- Da Fixer Upperz: Mek tools that succeed to repair on a 3+, big mek only. Says meks can use it, but meks can't get relics Supplement: Waaagh! GhazghkullSpecial rules - Warlord must always issue and accept challenges.- If your warlord kills a character in challenge, he rerolls to wound for the rest of the game.- +2 to mob rule result, but causes d3+3 rather than d6 hits. Warlord Traits 1. Supa-Shootist: Warlord has increased BS2. Waaagh! Mongerer: Warlord's unit has crusader3. Madboy: Warlord has the Rage USR4. Kunnin' Plan: Warlord and his unit gain outflank5. Kalling in a Favour: One of the warlord's weapons becomes master-crafted. Can't be a relic.6. Dead 'ard: Warlord gains FNP Relics - Choppa of da Ragnarork: Big choppa that gets +1S -1AP at end of turn if it caused a casualty.- Big Bosspole: Fearless- Da Supa-Cybork: FNP, EW, Relentless- Da Killa-Klaw: PK, can chose to trade all attacks for 1 Attack with the instant death special rule- Mega Force Field: 4++ KFF- Killa-Dakka: Random weapon, decide before game. Can be Deff Gun, Skorcha, Supa-Shoota, Zzap Gun, Grotzooka or Bubblechucka Please point out any mistakes I made and add anything I missed! Quote Link to comment Share on other sites More sharing options...
pretre Posted June 27, 2014 Author Report Share Posted June 27, 2014 So bit of a memory jog from yesterday's breif look at the Ghazzy Waaagh Supplement:1) There was a dread mob formation* unit gains hammer of wrath that inflicts d3 wounds*requires: 1 Big Mek, 1 Painboy, 2 Nauts, 3 deff dreds, 3 x 3 model unit of killa kanz2) 3x 5 model MegaNob formation (all meganobz gain +1 WS, fear, & fearless)3) there was a HQ formation*requires: Ghazzy, grotznik, 1 big Mek, 2 warbosses, 1 unit of nobz*all models in unit must deploy together*models with IC cannot join or leave the unit*as long as Waaagh banner is still alive all models in unit are fearless! and have +1 WS*friendly Ork models within 12" reroll failed morale & pinning*both Ork warbosses have +1WS*make 2 rolls on Waaagh Ghazghull warlord traits (reroll duplicates) and apply both to Ghazzy4) 5 Battlewagons (all battlewagons gain scout)*all Battlewagons must have rams or deff rollas*embarked units cannot charge if they go first5) da vulcha boyz.*requires 3 units of stormboyz & boss zagstruck*all units must start in reserves and must arrive via deepstrike*all hammer of wraith attacks gain shred*may form all units into one big mob. Counts as 3 units for VP purposes when destroyed6) snikrott formation*requires snikrott! & 4 units of kommandos*all units have the stealth rule replaced with shroud until the turn after they arrive*snikrott must join one unit*only make one roll for reserves for all units in formation*all units in formation enter same board edge*controlling player determines table edge*on the turn they arrive if a unit doesn't shoot, it may reroll failed cover saves Quote Link to comment Share on other sites More sharing options...
pretre Posted June 27, 2014 Author Report Share Posted June 27, 2014 3 Units of StormBoys in one Mob? Let me move this 90 boy mob and deepstrike it. lol Quote Link to comment Share on other sites More sharing options...
fluger Posted June 27, 2014 Report Share Posted June 27, 2014 Can it please be tomorrow already? Quote Link to comment Share on other sites More sharing options...
pretre Posted June 27, 2014 Author Report Share Posted June 27, 2014 I had Roy order one for me at DAG. He said next week though. Quote Link to comment Share on other sites More sharing options...
fluger Posted June 27, 2014 Report Share Posted June 27, 2014 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 27, 2014 Author Report Share Posted June 27, 2014 Meh, I'll live. Quote Link to comment Share on other sites More sharing options...
Threejacks Posted June 28, 2014 Report Share Posted June 28, 2014 I don't know now..im feeling kinda bummed out that ive checked out the dex:( -Cybork is pretty much worthless now.This is a huge thing for me as its one of the more reliable defences to getting shot off the board and with this change im assuming that the Dread Mob supplement will use the same "new" rule.Theres even Grotsnik who has Cybork Body..but also has Dok`s Tools. -RPJ is pretty much worthless now too. -The new mob rule is a bit iffy,I rather liked not having to worry about leadership with larger mobs, now a failure will likely mean a few more deaths...not sure on this one. -Waaagh is only on warbosses, and a trait if you happen to roll it. -Kans got nerfed with higher cost and a new str 7 klaw.Its still AP2 but was much more reliable against vehicles before and with the new vehicle damage chart that even hurts more.Also that stupid "Cowardly grots" rule now your few BS 3 shooting sources can snap shot half the game. Im kinda at a loss for what to build for now..guess ill have to see what you veteran players come up with as this is my first big Codex change in the game..well I guess the IG one was but that didn't seem nearly as drastic a change as this one is. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 28, 2014 Author Report Share Posted June 28, 2014 I think trukk boys and war bikes are standout right now. 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 28, 2014 Author Report Share Posted June 28, 2014 In fact, I imagine 6 trukk boys squads, a bike boss, 3 war bike squads, a lot of Mek guns and a Mek with KFF would be some fun. I still need the book though. 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 28, 2014 Author Report Share Posted June 28, 2014 Mek with KFF on a bike is a thing now. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 28, 2014 Author Report Share Posted June 28, 2014 People with too many Kans might think about converting them into Mek guns. ;) Quote Link to comment Share on other sites More sharing options...
Threejacks Posted June 28, 2014 Report Share Posted June 28, 2014 Yeah, speed is likely going to be the most viable for anyone trying to be competitive.Ive never really done a full on speed list but I do have a Biker wb coverted(trike,hehe) and 4 biker Nobs built plus 3 trukks so I guess I should work toward that. Actually the Warband formation may work out with mostly trukk boys and Biker Boss with Biker Nobs.The Waaagh each turn should guarantee face time early and keep it going especially with Planks on the Trukks.Im thiking this route with perhaps a CAD with supporting speed like Defkoptas,Stormboyz and maybe some Gunz and or Lootas. Im still going to try a Stompa/Walker build though. Quote Link to comment Share on other sites More sharing options...
fluger Posted June 29, 2014 Report Share Posted June 29, 2014 People with the codex, is the Stompa a Lord of War or a Heavy Support? 1 Quote Link to comment Share on other sites More sharing options...
Threejacks Posted June 29, 2014 Report Share Posted June 29, 2014 People with the codex, is the Stompa a Lord of War or a Heavy Support? Its a LoW still. And with all the "Krap" that this new Dex has done for the Orks..I think its almost a must take now as its the only thing that wont be easy for most armys to blow off the board. Ive been following all the forum rants today since I knew that there would be plenty,heh.Is it normal for GW to do such major changes to armys like this?...I mean Orks weren't competitive in the current shooty environ to begin with and they have actually made them worse. Its really starting to look like Fantasy time for me.I should probably get some play in on my OnG`s as I hear theres a possible new book out for them before the end of the year,,,and yeah I should probably get some play time in before it gets "touched" Sorry for the rant I guess I was expecting too much from the release. 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 29, 2014 Author Report Share Posted June 29, 2014 It's probably a bit early to proclaim doom and gloom. I think they got some good buffs. 1 Quote Link to comment Share on other sites More sharing options...
VonVilkee Posted June 29, 2014 Report Share Posted June 29, 2014 Get stuck in plenty of good combat buffs...one of the psychic powers actually gives all models with ere we go +1 Attack wow! Either way I have to just laugh at your idea to go to fantasy orcs and goblins...you think the rules in 40k pin them as underdogs good luck on the fantasy side! It is even worse. 1 Quote Link to comment Share on other sites More sharing options...
jollyork Posted June 29, 2014 Report Share Posted June 29, 2014 Seems like the detachment with 9 troops, plus a weirdboy with Malefic, and a few boxes of daemon figs would be a lovely assault army. Not your grandfather's orks. 2 Quote Link to comment Share on other sites More sharing options...
Threejacks Posted June 29, 2014 Report Share Posted June 29, 2014 Get stuck in plenty of good combat buffs...one of the psychic powers actually gives all models with ere we go +1 Attack wow! Either way I have to just laugh at your idea to go to fantasy orcs and goblins...you think the rules in 40k pin them as underdogs good luck on the fantasy side! It is even worse. Ive done much better with my OnG`s in the short time I played them last year..learning the game even.They are certainly no power house but seem to have a lot more answers to what opponents can do than their 40k counterparts.Either way I play both and plan to bounce between both systems now and then:)..things like this codex release just tells me its probably getting close to break time,heh. As to my complaints,im really pissed about the new mob rule.I mean the way it was before you simply didn't have to worry about the low leadership with your mobs and seeing as how Orks weren't dominating the competitive play circuit in any way,why did they have to change that? Maybe theres something im missing here but can someone explain to me how the new Mob rule is better than the old one? Quote Link to comment Share on other sites More sharing options...
VonVilkee Posted June 29, 2014 Report Share Posted June 29, 2014 I remeber when orks were t4 guardsmen... They switched to the mean fighters that they are now. To me the mob rule just forges a narrative, orks are not absolutely courageous just cuz they have some friends. They are far more likely to act individually. I picture the mob rushing forward taking fire and some of the boyz decide to press on while others decide to run for the hills (the casualties). When the original mob rule with the fearless bit was written you took extra wounds in combat for the difference in scores. The straight fearless and just consistent staying power of boyz units never sat right with me. Orks don't fear death but they aren't the best at staying alive and sometimes they get excited about all the teef they just found and run back home to buy a louder shoota to kill stuff better. 2 Quote Link to comment Share on other sites More sharing options...
