pretre Posted June 18, 2014 Author Report Share Posted June 18, 2014 I was continuing the song... I was oblivious. Quote Link to comment Share on other sites More sharing options...
Android Posted June 18, 2014 Report Share Posted June 18, 2014 I'm seriously totally freaking out right now. I got into 40k BECAUSE of Orks. And especially the crazy artillery. The artillery coming back (I want squig catapults!) is awesome IMO. Pretty excited. Also I totally use squig catapults for my lob as. 2 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 So, Black Library screwed up and has let a random amount of people download the codex... This is from Skullchewer from Warseer (who gave use the orinal model rumors)HQs listed asBig mek, Zagstruk (!!!), Badrukk (We knew that was coming), Grotsnik, Mek (Not big mek), Painboy, Warboss, Weirdboy.No Wazdakka, no Zogwort.Relics are in. Not had time to read.Buggys don't get new weapons, do get Grot Riggers at 10 points.Not seen anything about FNP at all yet.Grot riggers don't just work for IWND on 'nauts, any vehicle that has them, but cost per vehicle seems to differ. 20 to put them on a 'naut. BW don't seem to have the option.Looks to be a lot more options with selecting wargear for meks"A Big Mek may take items from the Mek Weapons, Melee Weapons, Runts & Squigs, Orky Know-wots and/or Gifts of Gork and Mork lists."Mob rule is replaced by the D6 roll, yes.Kustom Mega Slugga is a thing.A Big Mek with mega armour can take one of the following- Tellyport blasta- Kustom force fieldRelics:Gifts of Gork and MorkDa Dead Shiny ShootaDa Finkin’ KapDa Fixer UpperzDa Lucky StikkHeadwoppa’s KillchoppaWarboss Gazbag’s BlitzbikeD6 Result1If the unit is locked in combat, it passes the Morale check or Pinning test. If the unit is not locked in combat, it fails.2-3If the unit includes one or more Ork characters (including Independent Characters), it suffers D6 Strength 4 AP- hits, and is then treated as if it had passed the Morale check or Pinning test.4-6If the unit has 10 or more models, it suffers D6 Strength 4 AP- hits, and is then treated as if it had passed the Morale check or Pinning test. The hits are Randomly Allocated. If the unit has fewer than 10 models, it fails the Morale check or Pinning test.Tellyporta blasta is the back mouned thing I've been describing and seems... uh, situational at best? Very short range weapon but causes instant death on a 6 wound. Rolling a 6 on AP causes a penetrating hit regardless of AV.Stompa in as super heavyBW up 20 points.D6 Warlord Trait1 Prophet of the Waaagh!: Mork (or possibly Gork) has chosen this Warlord for greatness, and every Ork under his command knows it.The Warlord gains the Waaagh! special rule. If the Warlord already has the Waaagh! special rule then, in addition to the usual effects, all friendly models with the ’Ere We Go! special rule gain the Fearless special rule when he calls a Waaagh!, until the start of their next turn.2 Bellowing Tyrant: This Warlord is an unholy terror, a roaring lunatic whose every (very loud) word is law.The Warlord, and all friendly units with the Orks Faction within 12" of him, re-roll failed Morale checks and Pinning tests.3 Like a Thunderbolt!: This Warlord is a master of the all-out, no-holds-barred, headlong charge into battle.The Warlord, and all friendly units with the Orks Faction within 12" of him, can re-roll all the dice when determining Run moves or charge range.4 Brutal but Kunnin’: This Warlord has a sneaky streak a mile wide and knows just where to hit his foes.The Warlord can re-roll one failed To Hit or To Wound roll each turn.5 Kunnin’ but Brutal: The Warlord knows when to roll with a punch, and can shrug off the hardest blows.The Warlord can re-roll one failed armour or invulnerable saving throw each turn.6 Might is Right: Made of muscle and aggression, this Warlord is the embodiment of the Orks’ warlike nature.The Warlord receives +1 to the Strength characteristic on his profile.From NotMyIfurita:attack squig nerfed to 1 reroll in melee per turnBadrukk has the rules listed for Da Rippa, but it is not listed in his wargear.Yay Tankbustas can shoot at whatever they like, and Bustas and Burnas can take dedicated trukksKommandos get Stealth now, thats nice.. and they didnt see a point hike like burnas and tankbustaseww.. Ramshackle got clobbered.. 6+ save when you take a pen, if successful downgrade to glanceBuggies in units of 5, gained outflank and a minor point decrease.Snikrot is not HQ, effectively works like before when you add to Kommandos. Listed Elite. No slot if you bring Kommandos. He has Ambush and it gives Shrouded instead of Stealth the turn they arrive... still no charge from ReservesKillkannon still lowers transport on BWRule for planks is a little complicated. If you get out of open topped and declare a charge, add 2 to the charge rangeDeffrolla gains AP4 and loses half the hitsLootas HS and cheaper (shocking)I dont see any way to get Kans or Dreads as troopsKans come in 6 packsWow.. Ghazzy is a LoW but I can't see why.. they didnt change himWow.. if you take an Ork Warband detachment, you can Waaaagh every turn after the first 2 Quote Link to comment Share on other sites More sharing options...
jollyork Posted June 20, 2014 Report Share Posted June 20, 2014 Very characterful. Sounds like a lot of fun on the tabletop. 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Right, home with a pint of cider in me, and several more in the fridge...Weirdboys gain a Warp Charge point if there are 10 or more models with the 'ere we go rule (Pretty much any Ork from what I've seen) in 12" but has to take a psychic save or take a hit.Power of the Waaagh! and Daemonlogy disciplines.Can be upgraded to Psyker level 2.Primaris power is Frazzle (Blast witchfire).'Eadbanger is now a focussed witchfire.Warpath is a self blessingDa jump is what used to be 'ere we go.Killbolt is a beam attack.Power vomit (Yes really) is a template witchfire.Da Krunch is a barrage witchfire. Apparently you can buy it from Black Library and download right now. There's a bug. 1 Quote Link to comment Share on other sites More sharing options...
Romans832 Posted June 20, 2014 Report Share Posted June 20, 2014 LOL, I love his style: "with a pint of cider in me and many more to go..." Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Ded shiny shoota: 6 shots twinlinked shoota, rolls of 1 hit one of your own units. The bike relic has an AP3 deff gun on it, Hedwompas choppa is a +2 str, AP5, rending choppa that beheads on a roll of 6 (insta death).Big Mek doesnt change your FoC, nor does warboss (no more nob/dred troops).Mek is a slotless HQ, 1 per actual HQ boughtGhaz can take runts/squigs, but looks the same, its lord of war. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 No new character, Wazdakka is gone, No bikes as troops (pain boy can take a bike tho?)Kff is MODELS within 6 inches get 5++, if embarked than vehicle gets this INSTEAD 1 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 I'll have to wait to see the codex, but my Ork army may now be completely invalidated. Quote Link to comment Share on other sites More sharing options...
TW_Haines Posted June 20, 2014 Report Share Posted June 20, 2014 nice thing about Ghaz being a l.o.w. is that just 1 more hq in your list, but still dont think he belongs there and abadon is still not. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Dakka jet guns now only fire one more shot than normal on a Waaagh, not everything twice. Deff Koptas look the same, and picture is the old metal model.Bikes only get +1 to their cover save if they turbo boost, no more gas and smoke cloud Ugh. Anyone want to buy a really nice Ork Biker army? Quote Link to comment Share on other sites More sharing options...
fluger Posted June 20, 2014 Report Share Posted June 20, 2014 I love that they take the time to write out the names of the items, but not what they do. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Best I can do is $3.50 $350 it is. ;) Quote Link to comment Share on other sites More sharing options...
scottshoemaker Posted June 20, 2014 Report Share Posted June 20, 2014 Ugh. Anyone want to buy a really nice Ork Biker army? Unbound...or wait for formation, or multiple detachments... Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 No no no, I have to make a profit, and there's no telling how long these will stay on the shelf. Let me call a guy I know. lol fair enough. In reality, I'm waiting for the book to figure out what's up. I know bikes are like 17 a pop now, so that's nice. That's a lot more bikes I can put down. I just need more grots, I guess. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Storm Boys are now cheaper, and can be in Mobs of 30, no longer kill themselves unless they do their new 2D6 run (they take dangerous terrain tests for doing so) 80 Point Deff Dred, comes with 2 big shootas, rokkit are a free exchange. KMB are +5 point Exchange. Riggers are 10 points Wagon went up by 20, Kill Kannon is now half the price for it, 5 point drops for both lobba and Zzap gun on it. Weapon options the same as ever.Trukk dropped by 5, ramshackle is now a 6 to move a pen to a glance. Rokkit is a free exchange. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Ghaz is eternal warrior, but lost whatever Adamantium skill did for him. (Points, stats, wargear the same otherwise)Painboy gives FNP, independant character, urty syringe (4+ poison, AP - ) Grotzooka stats the same, Big Choppa gained AP 5, Nobz got a very mild points drop. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Da Lucky Strike Relic: +1 WS, In addition the user can choose to reroll any failed to hit, to wound or saving throws they make. If they fail 3 of these rerolls in a single turn they are removed as a casualty. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Good changes: Cheap IWND on vehicles (5 points on Kans, 10 on dreds)Relics are cool and give variety.Psychic powers are good.Warlord traits are all useful (none of this "gives fear" rubbish)Alot of point drops across the board.KFF can be combined with mega armour and bikes, Shock attack gun seems to be combinable with bikes.Git finda on SAG mek?Painboy is IC, so put him where you need him, can take a bike.Mega nobz look cool.Dedi transports available for burnas and tank bustas now. Quote Link to comment Share on other sites More sharing options...
TW_Haines Posted June 20, 2014 Report Share Posted June 20, 2014 Any chance there a relic that adds eternal warrior? wondering if orks can make a smash mouth hq somthing on par with a chapter master with the eternal shield? Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Greentide has a formation that can help it (need 6 boys squads and a bunch of stuff). Got more expensive if you are using shoota boys.Bikers got cheaper, less durable but in much larger mobs. Use the FW warboss and run these as troops and add in a mek with KFF or painboy on bike for durability.Trukk got cheaper, boys got free stick bombs, ramshackle for nerfed.Dreds got cheaper, Kans cost more, all their weapons are cheaper. Can get IWND from riggers. Dred mobs will be fierce.Lots of guns, Lootas are as good and cheaper, new mek guns are good, Git findas on big mek with shock attack gun (can vortex). Pretty good.Psyker heavy (you can fit in 2 weird boyz, not really heavy), powers are awesome but you'll be tight on warp charges (max lvl is 2)Mixed... the codex seems fun, some nice relics some minor changes here and there. Some nerfs and some price drops. I didn't see anything with EW. Bikes get you up to T6 though, I imagine. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 It would be nice if someone posted it up so I can preview it, but we'll see. Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 What's the new FOC look like, before I fly to the UK with my own Choppa?3 HQ, 9 Troop, 3 Heavy, 3 Fast, 3 Elite. Minimum is 1 HQ 3 TROOP.This is OPTIONAL instead of the standard FOC, you can still use the core books one. Quote Link to comment Share on other sites More sharing options...
fluger Posted June 20, 2014 Report Share Posted June 20, 2014 3 Quote Link to comment Share on other sites More sharing options...
pretre Posted June 20, 2014 Author Report Share Posted June 20, 2014 Oooh, someone brought up a good point re: Bikes and no more exhaust cloud. They do get Jink. So either 4+ or 3+ cover and they only really go from a 5+ to a 6+ to hit. :) Quote Link to comment Share on other sites More sharing options...
