Guest Posted January 13, 2019 Report Share Posted January 13, 2019 Does it matter from a game mechanic standpoint if no all my models with skimmer bases are on actual skimmer bases, but are instead on regular bases of the same width? I don't think it matters, but I figured I ask before I did it. I bought some used Pirhanhas and now I have more drones and skimmers than I have skimmer bases. I have extra clear stems, 32mm rounds, and 60mm rounds, but the rounds aren't clear or thin like the skimmer ones are. Think it would create a problem? Quote Link to comment Share on other sites More sharing options...
Kelharis Posted January 13, 2019 Report Share Posted January 13, 2019 Dont think it matters at all, especially since many people paint the skimmer bottom to match their other bases. Quote Link to comment Share on other sites More sharing options...
SPaceORK Posted January 13, 2019 Report Share Posted January 13, 2019 Custode bikes come with both options so... Quote Link to comment Share on other sites More sharing options...
Ish Posted January 13, 2019 Report Share Posted January 13, 2019 All that really matters (and it doesn't even matter that much) is that the bases be of the appropriate diameter. Citadel's skimmer bases stems are infamously prone to breakage and a lot of people use third-party alternatives. 1 Quote Link to comment Share on other sites More sharing options...
Lyraeus Posted January 13, 2019 Report Share Posted January 13, 2019 I keep forgetting the skimmer bases for my Deff Koptas but it's measured from hull for them. Quote Link to comment Share on other sites More sharing options...
andy Posted January 14, 2019 Report Share Posted January 14, 2019 Deff Koptas have bases? Quote Link to comment Share on other sites More sharing options...
Ish Posted January 14, 2019 Report Share Posted January 14, 2019 5 minutes ago, andy said: Deff Koptas have bases? Same flight stand used for Land Speeders and Jetbikes. 1 Quote Link to comment Share on other sites More sharing options...
andy Posted January 14, 2019 Report Share Posted January 14, 2019 1 minute ago, Ish said: Same flight stand used for Land Speeders and Jetbikes. Cool, thanks. I got a bunch in trade years ago, and they're standless (though probably due to me losing the stands and forgetting) Quote Link to comment Share on other sites More sharing options...
Ish Posted January 14, 2019 Report Share Posted January 14, 2019 Given how @#$%-ing fragile the Citadel Flight stands are, I wouldn't be surprised if your trade didn't come with any. Quote Link to comment Share on other sites More sharing options...
Sgt. Rock Posted January 14, 2019 Report Share Posted January 14, 2019 I saw a conversion once where a guy used a long, thin bolt screwed into a nut he glued onto the flight stand and again on the bottom of the vehicle. Worked a champ, never broke, and was easy to remove and transport. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2019 Report Share Posted January 14, 2019 Thanks. Thought it was worth double checking before I did it. Oh, worth knowing, GW flight bases as per their description are 32mm for small and 60mm for the larger. https://www.games-workshop.com/en-US/Citadel-Ball-Top-Flying-Stems-with-32mm-Flying-Bases https://www.games-workshop.com/en-US/Citadel-Ball-Top-Flying-Stems-with-60mm-Flying-Bases Quote Link to comment Share on other sites More sharing options...
WestRider Posted January 14, 2019 Report Share Posted January 14, 2019 41 minutes ago, paxmiles said: Thanks. Thought it was worth double checking before I did it. Oh, worth knowing, GW flight bases as per their description are 32mm for small and 60mm for the larger. https://www.games-workshop.com/en-US/Citadel-Ball-Top-Flying-Stems-with-32mm-Flying-Bases https://www.games-workshop.com/en-US/Citadel-Ball-Top-Flying-Stems-with-60mm-Flying-Bases The small ones match up almost perfectly with the other GW 32mm bases, but the large ones are noticeably smaller than other GW 60mm bases. I think they're like 57mm or so. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2019 Report Share Posted January 14, 2019 2 minutes ago, WestRider said: The small ones match up almost perfectly with the other GW 32mm bases, but the large ones are noticeably smaller than other GW 60mm bases. I think they're like 57mm or so. I also think there is a size difference, but the GW site says they are 60mm. Quote Link to comment Share on other sites More sharing options...
WestRider Posted January 14, 2019 Report Share Posted January 14, 2019 GW hasn't always been great with their actual size matching up to their nominal size 😉 Quote Link to comment Share on other sites More sharing options...
Ish Posted January 14, 2019 Report Share Posted January 14, 2019 I think they dropped the 32 mm ones from their line up. The Primaris Inceptors use a new, kinda crescent-shaped flight stem that attaches to a normal black base. Quote Link to comment Share on other sites More sharing options...
SPaceORK Posted January 14, 2019 Report Share Posted January 14, 2019 One would think that the tau players in the area would have a plethora of extra bases lying about they may be willing to part with. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2019 Report Share Posted January 14, 2019 4 hours ago, Ish said: I think they dropped the 32 mm ones from their line up. The Primaris Inceptors use a new, kinda crescent-shaped flight stem that attaches to a normal black base. I think my crisis suits came with those too. Quote Link to comment Share on other sites More sharing options...
